I cannot send sensor value to blynk while blynk online pls help me
@Pruek_Hoonkaew please edit your post, using the pencil icon at the bottom, and add triple triple backticks at the beginning and end of your code so that it displays correctly.
@Pruek_Hoonkaew you’ve visited the forum again since I posted the message asking you to fix the formatting on your code…
But, as you haven’t made any attempt to fix the problem, I’ve deleted the unformatted code.
Please either edit your original post to insert correctly formatted code, or post the correctly formatted code in a new post within the same topic.
You will also need to post the contents of defines.h
, Credentials.h
and dynamicParams.h
if you want people to be able to understand and diagnose your code.
