I want to push data to blynk server by using sim900A with arduino uno
This is my code
#define TINY_GSM_MODEM_SIM900
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
char auth[] = "token";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "internet";
char user[] = "true";
char pass[] = "true";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
void myTimerEvent()
// Set GSM module baud rate
SerialAT.begin(115200);
delay(3000);
//modem.restart();
// Unlock your SIM card with a PIN
modem.simUnlock("1234");
and the result is cannot init
