Cannot init modem Arduino Uno and Blynk
I’m making a very simple project with Arduino Uno, GSM Shield sim900. I’m trying to turn a led on and off using Blynk app but when I try to connect to Blynk it gives me “Cannot Init”. Below is my code. Please I need help. I’ve been stuck on this for three days now.
http://twitter.com/blynk_app
Attention! Please check out TinyGSM guide:
https://tiny.cc/tinygsm-readme
Change GPRS apm, user, pass, and Blynk auth token to run :)
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "TMPLbIjAHBxD"
// Select your modem:
//#define TINY_GSM_MODEM_SIM800
#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
#define BLYNK_HEARTBEAT 8
#include <TinyGsmClient.h>
char auth[] = "kuY0APZt2u9LlR7rgN2Plt4eQSzB2XfM";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "internet.ideasclaro";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
// Set GSM module baud rate
SerialAT.begin(9600);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
My At Debug
* This script tries to auto-detect the baud rate
* and allows direct AT commands access
* TinyGSM Getting Started guide:
* https://tiny.cc/tinygsm-readme
// #define TINY_GSM_MODEM_SIM808
// #define TINY_GSM_MODEM_SIM868
// #define TINY_GSM_MODEM_UBLOX
// #define TINY_GSM_MODEM_M95
// #define TINY_GSM_MODEM_BG96
// #define TINY_GSM_MODEM_A6
// #define TINY_GSM_MODEM_A7
// #define TINY_GSM_MODEM_M590
// #define TINY_GSM_MODEM_MC60
// #define TINY_GSM_MODEM_MC60E
// #define TINY_GSM_MODEM_ESP8266
// #define TINY_GSM_MODEM_XBEE
// Set serial for debug console (to the Serial Monitor, speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#ifndef __AVR_ATmega328P__
#else
#endif
#define TINY_GSM_DEBUG SerialMon
// Module baud rate
uint32_t rate = 0; // Set to 0 for Auto-Detect
// Set console baud rate
SerialMon.begin(115200);
delay(6000);
if (!rate) {
rate = TinyGsmAutoBaud(SerialAT);
if (!rate) {
SerialMon.println(F("***********************************************************"));
SerialMon.println(F(" Module does not respond!"));
SerialMon.println(F(" Check your Serial wiring"));
SerialMon.println(F(" Check the module is correctly powered and turned on"));
delay(30000L);
return;
SerialAT.begin(rate);
// Access AT commands from Serial Monitor
SerialMon.println(F(" You can now send AT commands"));
SerialMon.println(F(" Enter \"AT\" (without quotes), and you should see \"OK\""));
SerialMon.println(F(" If it doesn't work, select \"Both NL & CR\" in Serial Monitor"));
while(true) {
if (SerialAT.available()) {
SerialMon.write(SerialAT.read());
if (SerialMon.available()) {
SerialAT.write(SerialMon.read());
delay(0);
