Cannot get ethernet sketch to compile
Trying to compile but am getting a won’t declare Blynk error code. Can I get any help please?
You are not giving us much to work with here…
Can you provide more information?
What have you done so far?
Are you using the example sketch?
What hardware?
I have connect the new arduino uno with ethernet sheild. I downloaded the sketch that I thought would be for it. I plugged in the code. And tried to compile the sketch. But I am getting and error code. Blink was not declared in this scope. Thank you for any help in this matter.
Jerry Fox
Please post here your code and error you are getting.
@jfox if Blynk was not declared it suggests you don’t have the 4 libraries required for Blynk.
