Cannot connect with python lib, but OK with http interface
Hello .
I’m a Blynk plus plan customer.
I am using the python lib "for Python v0.2.6 " on raspberry PI (Debian GNU/Linux 11 (bullseye) 64 bits
#server = ‘lon1.blynk.cloud’
server = ‘blynk.cloud’
blynk = blynklib.Blynk(“MYAUTH”, server=server)
blynk.connect() FAILS,
HOWEVER
https://blynk.cloud/external/api/get?token=MYAUTH&v11 is OK (which means the AUTH TOKEN is OK)
blynk.connect() fails in _authenticate with status = 4
raise BlynkError(‘Auth stage failed. Status={}’.format(status))
I tried with my geo zeone : lon1.blynk.cloud, but same problem.
I have already one other device (different template) working with blynk v2.0, and my plans allows for 10 devices
I am stuck. Can you help ?
happy blynking …
You should update the library to the latest version (1.0.0).
But you have to do that manually.
