Hello, I am now using python to connect raspberry pi 4 model B with Blynk. However, the connection shown on Blynk always offline even they are all in the same internet connection. Is there any code’s problem as the output came out with no error.
The code for main1.py:
BLYNK_TEMPLATE_ID = "TMPL6818TwA8M"
BLYNK_TEMPLATE_NAME = "IoT Project 1"
BLYNK_AUTH = "L2GSGH1gM0_FR2H-eAQqPmvTPmdKNzW_"
import RPi.GPIO as GPIO
from ldr_pr import LDR
import blynklib
from blynkapi import Blynk
import sys
LED_1 = Blynk(BLYNK_AUTH, pin = "V5")
LED_2 = Blynk(BLYNK_AUTH, pin = "V7")
LED_3 = Blynk(BLYNK_AUTH, pin = "V6")
All_LED = Blynk(BLYNK_AUTH, pin = "V3")
DEC = Blynk(BLYNK_AUTH, pin = "V8")
blynk = blynklib.Blynk(BLYNK_AUTH)
WRITE_EVENT_PRINT_MSG = "[WRITE_VIRTUAL_PIN_EVENT] Pin: V{} Value: '{}'"
# register handler for virtual pin V5 write event
@blynk.handle_event('write V5')
def write_virtual_pin_handler(pin, value):
print(WRITE_EVENT_PRINT_MSG.format(pin, value))
def my_write():
GPIO.setmode(GPIO.BOARD)
GPIO.setwarnings(False)
GPIO.setup(18,GPIO.OUT)
GPIO.setup(15,GPIO.OUT)
GPIO.setup(16,GPIO.OUT)
p=0
for i in range(0,5):
p=p+LDR(11,13)
p_avg = p/5
blynk.virtual_write(2, '{:.2f}'.format(p_avg))
#print(p_avg)
if p_avg > 500:
GPIO.output(18, GPIO.HIGH)
GPIO.output(15,GPIO.HIGH)
GPIO.output(16,GPIO.HIGH)
value=1
blynk.virtual_write(3, value)
else:
GPIO.output(18, GPIO.LOW)
GPIO.output(15,GPIO.LOW)
GPIO.output(16,GPIO.LOW)
value=0
READ_PRINT_MSG = "[READ_VIRTUAL_PIN_EVENT] Pin: V{}"
# register handler for virtual pin V3 reading
@blynk.handle_event('read V3')
def read_virtual_pin_handler(pin):
print(READ_PRINT_MSG.format(pin))
blynk.virtual_write(pin, random.randint(0, 255))
def my_read():
first_led=LED_1.get_val()
second_led=LED_2.get_val()
third_led=LED_3.get_val()
ld_1=int(float(first_led[0]))
ld_2=int(float(second_led[0]))
ld_3=int(float(third_led[0]))
if ld_1==1:
else:
GPIO.output(18,GPIO.LOW)
if ld_2==1:
GPIO.output(15, GPIO.HIGH)
else:
if ld_3==1:
GPIO.output(16, GPIO.HIGH)
else:
try:
while True:
dc = DEC.get_val()
if dc and isinstance(dc[0], (int, float)):
dec = int(float(dc[0]))
if dec == 0:
my_write()
else:
my_read()
blynk.run()
except KeyboardInterrupt:
sys.exit(0)
The code for ldr_pr.py:
import time
def LDR(cpin,lpin):
cap=0.0000001
adj=2.130620985
GPIO.setup(cpin, GPIO.OUT)
GPIO.setup(lpin, GPIO.OUT)
GPIO.output(cpin, False)
GPIO.output(lpin, False)
time.sleep(0.2)
GPIO.setup(cpin, GPIO.IN)
time.sleep(0.2)
GPIO.output(lpin, True)
starttime=time.time()
endtime=time.time()
while (GPIO.input(cpin) == GPIO.LOW):
endtime=time.time()
measureresistance=endtime-starttime
res=(measureresistance/cap)*adj
return(res/10)
