Before creating the topic
Search forum for similar topics
Check http://docs.blynk.cc and http://help.blynk.cc/
Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
#define TINY_GSM_MODEM_SIM900
#include <TinyGsmClient.h>
char auth[] = "4*********************************";
char apn[] = "mobitel";
char user[] = "";
char pass[] = "";
SoftwareSerial SerialAT(7, 8); // RX, TX
TinyGsm modem(SerialAT);
WidgetLED Power(V1);
SerialAT.begin(9600);
delay(3000);
modem.restart();
String modemInfo = modem.getModemInfo();
Serial.print("Modem: ");
Serial.println(modemInfo);
Serial.println(Blynk.connected());
Power.on();
Blynk.virtualWrite(V0, 22, 3, 12, 24);
Blynk.virtualWrite(V2, 22);
Blynk.virtualWrite(V3, 12);
Blynk.virtualWrite(V4, 24);
I’m using arduino uno with gsm 900 sheild.
Blynk Library version is 0.6.1
Smartphone OS is anrdoid and the app version is 2.27.5
Modem: SIM900 R11.0
[12774]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Arduino Uno
[12890] Modem init...
[13817] Connecting to network...
[14893] Network: Mobitel
[14894] Connecting to mobitel ...
[21720] Connected to GPRS
[21989] Connecting to blynk-cloud.com:80
[24375] Redirecting to 45.55.96.146:80
[24814] Connecting to 45.55.96.146:80
[27117] Ready (ping: 866ms).
[33122] Connecting to 45.55.96.146:80
[35477] Ready (ping: 948ms).
[40918] Connecting to 45.55.96.146:80
[43202] Ready (ping: 908ms).
[49045] Connecting to 45.55.96.146:80
[51106] Ready (ping: 714ms).
[57122] Connecting to 45.55.96.146:80
[64367] Connecting to 45.55.96.146:80
[66984] Ready (ping: 952ms).
[73000] Connecting to 45.55.96.146:80
[75991] Ready (ping: 897ms).
[81126] Connecting to 45.55.96.146:80
Read this:
You’re breaking all of the rules with your void loop.
It is still the same
Modem: SIM900 R11.0
[13217]
___ __ __
[13332] Modem init...
[14284] Connecting to network...
[15360] Network: Mobitel
[15361] Connecting to mobitel ...
[21243] Connected to GPRS
[21514] Connecting to blynk-cloud.com:80
[23641] Redirecting to 45.55.96.146:80
[24129] Connecting to 45.55.96.146:80
[26186] Ready (ping: 707ms).
[32203] Connecting to 45.55.96.146:80
[43506] Connecting to 45.55.96.146:80
[45939] Ready (ping: 929ms).
[51956] Connecting to 45.55.96.146:80
[56076] Connecting to 45.55.96.146:80
[58303] Ready (ping: 709ms).
[63439] Connecting to 45.55.96.146:80
[65684] Ready (ping: 809ms).
[71701] Connecting to 45.55.96.146:80
[91304] Connecting to 45.55.96.146:80
[93471] Ready (ping: 829ms).
[99494] Connecting to 45.55.96.146:80
[101752] Ready (ping: 870ms).
[107753] Connecting to 45.55.96.146:80
delay(3000);
modem.restart();
Serial.println("Started");
I think it stuck in “Blynk.begin(auth, modem, apn, user, pass);”
Modem: SIM900 R11.0
[19333]
___ __ __
[19448] Modem init...
[20423] Connecting to network...
[20715] Network: Mobitel
[20715] Connecting to mobitel ...
[26170] Connected to GPRS
[26440] Connecting to blynk-cloud.com:80
[28633] Redirecting to 45.55.96.146:80
[29077] Connecting to 45.55.96.146:80
[31115] Ready (ping: 707ms).
[38308] Connecting to 45.55.96.146:80
[41138] Ready (ping: 911ms).
[47154] Connecting to 45.55.96.146:80
[72766] Connecting to 45.55.96.146:80
[75085] Ready (ping: 884ms).
[81101] Connecting to 45.55.96.146:80
Gunner
April 28, 2019, 4:15am
5
mindiya:
It is not stuck… since it IS successfully connecting, as indicated by the Ready (ping:...) statement.
So more likely something else is causing a disconnection… Power brownout, Blocking code, Cell provider…???
Since it can’t seem to get to your first serial print and there seems to be a around 5-7 seconds or so between reconnections, I suspect a power brownout as the connection ramps up.
I’m using a power supply to power the sim900 module.
When reconnecting it gives 0.5amps
Did you ever resolve this? I am running into the same issue…
