I installed recently blynk server on my VPS. I can connect to the server with the app, but when i try to connect my adruino uno (via usb serial with included blynk script), it looks like the connection gets somehow interrupted.
so, this is output form script:
Connecting device at COM11 to 80.211.207.110:8440...
OpenC0C("\\.\COM11", baud=9600, data=8, parity=no, stop=1) - OK
Connect("80.XXX.XXX.110", "8440") - OK
InOut() START
DSR is OFF
Received EOF
EVENT_CLOSE
InOut() - STOP
Disconnect() - OK
InOut() START
DSR is OFF
Variables in script is:
set COMM_PORT=COM1
set COMM_BAUD=9600
set SERV_ADDR=80.211.207.110
set SERV_PORT=8440
server,prop contains:
web.request.max.size=524288
user.tags.limit=100
net.interface=eth
user.devices.limit=50
notifications.frequency.user.quota.limit=15
user.profile.max.size=1280
profile.save.worker.period=60000
data.folder=/root/Documents/
server.ssl.cert=
allowed.users.list=
user.message.quota.limit=100
enable.raw.db.data.store=false
enable.db=false
user.widget.max.size.limit=200
allow.reading.widget.without.active.app=true
stats.print.worker.period=60000
log.level=info
lcd.strings.pool.size=16
hardware.mqtt.port=8441
admin.pass=mampsikaterry
allowed.administrator.ips=0.0.0.0/0,::/0
listen.address=
http.port=8080
restore=false
server.ssl.key=
admin.rootPath=/admin
product.name=Blynk
csv.export.data.points.max=43200
force.port.80.for.csv=false
hard.socket.idle.timeout=15
async.logger.ring.buffer.size=2048
https.port=9443
logs.folder=/root/Documents/logs
webhooks.frequency.user.quota.limit=100
initial.energy=100000
blocking.processor.thread.pool.limit=6
table.rows.pool.size=100
admin.email=(removed for privacy protection)
map.strings.pool.size=25
server.ssl.key.pass=
hardware.ssl.port=8440
user.dashboard.max.limit=100
webhooks.response.size.limit=72
terminal.strings.pool.size=100
notifications.queue.limit=2000
I tried to change port in usb script, but it is only worse when i do it.
I really do not know where can be error, i hope, you do. Thanks, co-Blynkers
