Cannot add mobile dashboard after transfering device to suborganisation
I cannot create or edit mobile dashboard after transferring the device to suborganization.
on the mobile dashboard it is showing : “this device doesn’t have widgets yet. contact administrator.”
the device does not have any owner. its transfered to a sub organization with two members both have USER acess
Hi @sachinmc,
You moved to a sub organization and then go to the dev mode. Dev mod does not work in sub organizations, all changes you need to make in your root organization and they will be applied to the sub organization. You need to select “my household” in the right menu - go to the root organization - then go to the dev mod - select the desired template and then you can edit it.
Dmitriy from Blynk
