I’m using a nodemcu12 (not 12e) and I flashed it with micropython. I’m able to hop on webrepl and start using micropython. However, once I upload a blynk sketch to the nodemcu, I am no longer able to reach it via webrepl. Any suggestions?
Thanks!
Thanks!
Don’t know about in an NodeMCU, but Python is in Alpha for other MCU’s like the RPi. I don’t know the difference between it and MicroPython.
MicroPython can be used with the same Python library. I didn’t test it with NodeMCU yet.
Please post your feedback if you try it! I think it should work.
micropython works great on the nodemcu. problem is, once I upload a blynk sketch, i am no longer able to access the micropython interpreter
Please read community forum rules. Which exactly code do you use, wiring, etc. Are we telepathics/magicians?
LOL Mind reader!
micropython is firmware that allows you to execute python commands on boards like the nodemcu. I’m using the latest version (v1.9.3-8-g63826ac5c). Once the firmware is loaded, I use the interpreter to set up the network and webrepl (the ability to access the nocdemcu via wireless interface) on the nodemcu.
My blynk app version is 2.18.0(1)
I have a power supply providing 3.3v@~240mA to the nodemcu.
I also have an led connected between pin 13 and ground with a R330 in line.
I can use Micropython to turn the led on and off. However, once I set up blynk to toggle the led, I can no longer get to my micropython interpreter to do anything. I have to reflash it.
So that’s my question. Is it one or the other? or can they coincide?
I still don’t see your code…
Code from where? Are you asking for the commands in micropython I use to configure?
Blynk is graphical, so there’s no code.
I’m not sure what you’re asking for
Did you completely miss all those code like commands and functions in the Documentation, Help Center and Sketch Builder
Blynk is a combo of an App, Server and Library… the primary Library being C++ based, but there is also a NodeJS and this Alpha version of Python based Blynk libraries.
I think the code we are looking for here is your Python code… what you posted is C++ and thus not really compatible to your topic’s issue ![]()
I followed the instructions in the Docs section:
http://docs.blynk.cc/#getting-started-getting-started-with-the-blynk-app
http://docs.blynk.cc/#hardware-set-ups-esp8266-standalone
Sketch builder?? Didn’t i just show you the sketch? How would it seem to you that I missed that??
I have a simple question: Can I continue to use MicroPython if I want to utilize Blynk? Can they coincide? or is it one or the other?
LOL man.
You flash it with MicroPython, then completely erase it with Your C++ sketch. What are you thinking about?
You were directly pointed to the micropython library…
“You flash it with MicroPython, then completely erase it with Your C++ sketch.”
That tells me everything I need to know.
Thanks!
I suspect not ![]()
But seriously… When you do get an actual Python sketch working… feel free to post it here so others can benefit and learn. Thanks.
A short tutorial / demo would be perfect!
