Hi, I am using a nodeMCU ESP8266 to upload ECG signal data to a superchart.
In order to have better output for the graph. Is it possible to save the analogRead(A0) values in an array and then virtual write it after 10ms?
Really need help with this. I am just using the basic virtualwrite. Can you suggest modifications?
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
char auth[] = "5dc460059a4a4136b74d55231e2cf359";
char ssid[] = "";
char pass[] = "";
#define ANALOGIN A0 // What digital pin we're connected to
void sendSensor()
int h = analogRead(A0)/10;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, A0);
timer.setInterval(100L, sendSensor);
