I can not setting Timer in app Blynk. I use iphone 7. Help me!
I would start by providing more information.
What type of timer widget (there are two), what pin is it attached to, what EXACTLY does “I cannot setting” mean in practice?
So are you saying that tapping the arrow at the side of the Start and Stop times has no effect?
Yes yes. I do not see time after I install
Is this the same when you put the app into “Play” mode and tap the timer widget?
If so, have you tried deleting the widget and re-adding it, or uninstalling the app and re-installing it?
I was put the app into ‘‘Play’’ but it not worked. I not see time. I tried reinstalling app but it still doesn’t work
