Hello there ,
I’m having problems adding devices when I change my Wifi location.
I tested my project at home, all Ok
but when i bring it to the company, where i want to setup it, i can’t add the device. I tried reupload the code but it still doesn’t work. (I try to bring it home, I can add the device normally.)
Am I missing a step? please help me
I am using Blynk 2.0
Hello. How do you add the device? Via mobile provisioning or something else? Company networks usually have firewalls or white-listed list of resources you can access.
I’m adding a device using a smartphone (IOS). I have turned off all firewalls. At the time I also tried with another Wifi connection . It’s useless. By adding the device from the web Console and inserting the Token in the code, it’s OK.
It’s not the RST button that you need to press, it’s the button connected to whatever pin is defined in the Settings.h tab for the board type you’ve chosen.
