Can I write value to the pin through Widget Terminal
What exactly are you trying to achieve?
Perhaps something like this …
WidgetTerminal terminal(V1);
BLYNK_WRITE(V1){
if (String("value") == param.asStr()) {
\\Do something
I presume the OP means this:
BLYNK_WRITE(V1){
Blynk.virtualWrite(pin, param.asInt())
I want to type a word or number in the terminal to be saved in EEPROM
Thank you problem has been solved
What was your solution?
Read and Write blynk to eeprom
It’s blynk magic
i love blynk
#include <EEPROM.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
char Command[12]=" ";
char Menu_1[12]=" ";
bool TEXT = false;
#define EEPROM_SALT 12664
typedef struct {
char textVal[9] = "No Text";
WMSettings;
WMSettings text;
EEPROM.begin(512);
EEPROM.get(0, text);
EEPROM.end();
BLYNK_WRITE(V1)
int j=0;
strcpy(Command,param.asStr());
for(int i = 0; Command[i]; i++){
Command[i] = tolower(Command[i]);
if ((String("new text") == Command)) {
terminal.println("Enter New Text\n ");
j=1;
strcpy(Menu_1,Command);
terminal.flush();
TEXT = true;
if ((!j) && TEXT == true) {
terminal.print("Save New text ");
terminal.println(Command);
strcpy(text.textVal, Command);
Save();
j=1;
terminal.flush();
TEXT = false;
if ((String("my text") == Command)) {
terminal.print("your text : ");
terminal.println(text.textVal);
j=1;
terminal.flush();
else if (!j)
{terminal.println("\nInvalid command");
terminal.flush();
TEXT = false;
void Save(){
EEPROM.begin(512);
EEPROM.put(0, text);
EEPROM.commit();
EEPROM.end();
