By default server starts on ipv6 interfaces, but with parameter -Djava.net.preferIPv4Stack=true it starts on ipv4, can I set to prefer ipv4 on server.properties config file?
It is starts on both IPv6 and IPv4. Doesn’t IPv4 works for you by default?
Yes, I tested on synology and Ubuntu 16.04 OS.
[~]$ java -jar server-0.16.4.jar &
[~]$ netstat -nlp | grep java
tcp6 0 0 :::8080 :::* LISTEN 47506/java
tcp6 0 0 :::8081 :::* LISTEN 47506/java
tcp6 0 0 :::8082 :::* LISTEN 47506/java
tcp6 0 0 :::7443 :::* LISTEN 47506/java
tcp6 0 0 :::8441 :::* LISTEN 47506/java
tcp6 0 0 :::8442 :::* LISTEN 47506/java
tcp6 0 0 :::8443 :::* LISTEN 47506/java
tcp6 0 0 :::9443 :::* LISTEN 47506/java
[~]$ java -Djava.net.preferIPv4Stack=true -jar server-0.16.4.jar &
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 7220/java
tcp 0 0 0.0.0.0:8081 0.0.0.0:* LISTEN 7220/java
tcp 0 0 0.0.0.0:8082 0.0.0.0:* LISTEN 7220/java
tcp 0 0 0.0.0.0:7443 0.0.0.0:* LISTEN 7220/java
tcp 0 0 0.0.0.0:8441 0.0.0.0:* LISTEN 7220/java
tcp 0 0 0.0.0.0:8442 0.0.0.0:* LISTEN 7220/java
tcp 0 0 0.0.0.0:8443 0.0.0.0:* LISTEN 7220/java
tcp 0 0 0.0.0.0:9443 0.0.0.0:* LISTEN 7220/java
Yes it doesn’t work? Did you try to connect without -Djava.net.preferIPv4Stack=true?
Yes, it doesn’t work on ipv4 by default. As you can see in my output when I run server without -Djava.net.preferIPv4Stack=true it runs only on ipv6 (tcp6 on netstat output).
Ok. Than answer is no on your question. But IPv4 should work anyway. At least it works for me.
