I am doing a small project on my own , and i just want to confirm that whther i can access my local blynk server when im out of my home.
I’d read this post in its entirety, and the other posts that are linked from within it…
yes. you need static ip address or you can use DDNS service like NOIP ( www.noip.com ) and forwarding your server ports 8080 and 9443
thaanks i will look into that
You can also use VPN if your router supports it. I have had good experiences with it.
Kind regards
djgan
