hi guys, I want to combine my code into blynk code, but after combine ,my keypad won’t function anymore
My code
#include<LiquidCrystal.h>
LiquidCrystal lcd(2,3,4,5,6,7);
int row[]={A0,A1,A2,A3};// Defining row pins of keypad connected to Arduino pins
int col[]={A4,A5,0,1};//Defining column pins of keypad connected to Arduino
int i,j,lcd_count,count=1,key_id=0,flag,entry=0;// See About the Program
int col_scan;// Variable to identify a key press
int inPin = 13; //button pin
int rPin = 8; //relay pin
int val = 0;
char temp_press; // Variable to hold value of key press
char check[6],pass[6]; // See About the Program
const int buzzer = 9; //buzzer to arduino pin 9
pinMode(inPin, INPUT);
pinMode(rPin, OUTPUT);
pinMode(9, OUTPUT);
pinMode(buzzer, OUTPUT);
lcd.begin(16,2);
for(i=0;i<=3;i++)
pinMode(row[i],OUTPUT);
pinMode(col[i],INPUT);
digitalWrite(col[i],HIGH);
lcd.print("SET 5 Digit PASS");
/* Main Program Begins */
val = digitalRead(inPin); // read input value
if (val == HIGH) { // check if the input is HIGH (button released)
digitalWrite(rPin, HIGH); // turn LED OFF
lcd.setCursor(0,0);
lcd.print("UNLOCKED");
delay(3000); // wait for a second
digitalWrite(rPin, LOW);
lcd.clear();
lcd.print("LOCKED");
digitalWrite(rPin, LOW); // turn LED ON
while(entry<=4)// Password Setting Loop begins
SetPassword();
// Password Setting Loop Ends
key_id=0;
keyscan(); // Scan for a Key Press
/* Actions on Key Press begins */
if(key_id==1) // Condition to Check Key is Pressed
check[count]=temp_press;
count++;
/* Condition to Unlock Begins*/
if(temp_press=='A')
checkPassword();
if(flag==0)
lcd.setCursor(0,0);
digitalWrite(rPin, HIGH); // turn the LED on (HIGH is the voltage level)
lcd.clear();
}else{
lcd.setCursor(0,0);
lcd.print("WRONG PASSWORD");
tone(buzzer, 18); // Send 1KHz sound signal...
delay(500); // ...for 1 sec
noTone(buzzer); // Stop sound...
lcd.clear();
count=1; // Resetting the counter variable
/* Condition to Unlock Ends*/
/* Condition to Change Password Begins */
else if(temp_press=='C')
checkPassword();
if(flag==0)
lcd.setCursor(0,0);
lcd.print("ENTER NEW PASS");
key_id=0;
entry=0;
}else{
lcd.setCursor(0,0);
/* Condition to Change Password Ends */
/* Condition to LOCK Begins*/
else if(temp_press=='B')
lcd.setCursor(0,0);
/* Condition to LOCK Ends*/
/* Actions on Key Press Ends*/
/* Main Program Ends */
void SetPassword() // Subroutine to SET User Defined Password
keyscan();
if(key_id==1)
if(temp_press=='A'||temp_press=='C'||temp_press=='B') // Condition to Check for an Invalid Keypress
lcd.setCursor(0,0);
lcd.print("INVALID KEYS");
entry=0;
pass[entry]=temp_press;
key_id=0;
if(entry==5)
lcd.clear();
lcd.setCursor(0,0);
lcd.print("PASSWORD SET & LOCKED");
}} // Subroutine to SET Password ENDS
char keyscan()// Subroutine to Scan Keypad for a Keypress
for(i=0; i<=3; i++)
digitalWrite(row[0],HIGH);
digitalWrite(row[1],HIGH);
digitalWrite(row[2],HIGH);
digitalWrite(row[3],HIGH);
digitalWrite(row[i],LOW);
for(j=0; j<=3; j++)
col_scan=digitalRead(col[j]);
if(col_scan==LOW)
key_id=1;
entry++;
temp_press=keypress(i,j);
lcd.setCursor(lcd_count++,1);
lcd.print(temp_press);
lcd_count=0;
lcd.clear();
delay(300);
break;
}}// Subroutine to Scan Keypress Ends
char keypress(int i, int j) // Subroutine to Identify the value of Key pressed
if(i==0&&j==0)
return('1');
if(i==0&&j==1)
return('2');
if(i==0&&j==2)
return('3');
if(i==0&&j==3)
return('A');
if(i==1&&j==0)
return('4');
if(i==1&&j==1)
return('5');
if(i==1&&j==2)
return('6');
if(i==1&&j==3)
return('B');
if(i==2&&j==0)
return('7');
if(i==2&&j==1)
return('8');
if(i==2&&j==2)
return('9');
if(i==2&&j==3)
return('C');
if(i==3&&j==0)
return('*');
if(i==3&&j==1)
return('0');
if(i==3&&j==2)
return('#');
if(i==3&&j==3)
return('D');
} // Subroutine to identify Keypress Ends
void checkPassword() // Subroutine to Check User Input Data with SET Password
flag=0;
for(i=1;i<=5&&flag==0;i++)
if(check[i]==pass[i])
flag=0;
{flag=1;
}}} // Subroutine to check password ends
Blynk code
SoftwareSerial DebugSerial(0, 1); // RX, TX
char auth[] = "my AuthToken";
DebugSerial.begin(9600);
Blynk.begin(Serial, auth);
Thanks!
