this question might sound dumb, but can a device connected to blynk legacy and blynk iot 2.0 at the same time?
You can run an old blynk sketch on a device and and run a new blynk sketch on other device then use api, Node-RED, or any alternative to send the data between your devices.
@Danial_Ghazali you’re starting multiple topics asking questions that are clearly related in some way, and which we’re attempting to answer as well as we can with the limited information that you’ve provided.
I’d suggest that you pick one of your existing topics and explain in detail exactly what it is that you’re trying to achieve, and why the answers that we’ve provided so far don’t help you to overcome the problem that you are having.
