I was wondering if it is possible to have a button from blynk issue a command on the raspberry pi when pressed?
Can you be a little more specific? What exactly are you trying to do?
I have gas sensors and laser trip wires connected to my pi. I want to be able to start and stop the python script that controls their alarm right from my blynk dashboard. Essentially like a armed/unarmed or on/off button.
I use child process to send commands to multiple 3rd party processes from my Blynk sketch… Python based OLED screen demos, PiCam commands to take pictures, BrightPi commands to turn on/off the White and IR LEDs, etc…
var process = require('child_process'); // Allows this script to run CLI commands
For example, this will reboot my RPi with a Button Widget on V20
// ----- RPi Reboot Command -----
var RPiReboot = new blynk.VirtualPin(20); // Setup Reboot Button
RPiReboot.on('write', function(param) { // Watches for V20 Button
if (param == 1) { // Runs the CLI command if the button on V520 is pressed
process.exec('sudo /sbin/shutdown -r', function (msg) { console.log(msg) });
Well you can have a code always running a loop that does nothing until the button is pressed and executes some code when the butto nis pressed.
The RPi NodeJS works differently… there is no “loop” perse as in C++
Well on JS is even easier. Just execute some code when the event of the write on the pin occurs
Edit: actually as you did on your code
your code seem to do the trick. too bad don’t understand c++. I’m more of a python mid level person.
