Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.Code should be formatted as example below.
Hello together,
i’am a new menber of the iot family.
i will control my water dispencer with ESP8266.therefore i build a blynk app with 2 slider to get glass-size and sparkling density for my cup. Everytime i use the sliders i get a value from virtualpin an can print it on serialmonitor. But if i try to calculate with teh value of the virtual pins i got no result even i declared the variables as global.
that’s the sketch
char auth[] = "3fee5cc8d13e4acfa76c9eebf8a6734e";
char ssid[] = "SvenRueckmann_iPhone";
char pass[] = "sven22";
int pinValueDensity;
int pinValueSize;
int maximumMilisekunden=60000; // 60000 Millisekunden=1 Minute=330 ml
int maximumGsize=330; // Glasgroesse 330 ml
int gstspark; //glas_size_time_sparkling_still Variable zur Steuerung des Zuflusses
int gststill; //glas_size_time_sparkling_still Variable zur Steuerung des Zuflusses
int gstssFaktorspark;//glas_size_time_sparkling_still Variable zur Steuerung des Zuflusses als prozentfaktor
int gstssFaktorstill; //glas_size_time_sparkling_still Variable zur Steuerung des Zuflusses als prozentfaktor
BLYNK_CONNECTED() {
Serial.println("*** Sync All ? ***");
Blynk.syncAll();
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
pinValueDensity = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.print("sparkling density % is: ");
Serial.println(pinValueDensity);
fehlersuche();
faktor();
fehlersuche();
BLYNK_WRITE(V2)
pinValueSize = param.asInt(); // assigning incoming value from pin V2 to a variable
Serial.print("glass size ml is: ");
Serial.println(pinValueSize);
fehlersuche();
faktor();
fehlersuche();
// die wird nicht benutzt, weil sie gar nicht funktioniert
void laufzeit()
gstspark=0;
gststill=0;
gstspark=maximumMilisekunden*pinValueDensity/100*pinValueSize/maximumGsize;
gststill=maximumMilisekunden*(100-pinValueDensity)/100*pinValueSize/maximumGsize;
Serial.print("Laufzeit Sparkling in Sekunden ist : ");
Serial.println(gstspark/1000);
Serial.print("Laufzeit Still in Sekunden ist : ");
Serial.println(gststill/1000);
void faktor()
//gstssFaktorspark=1+(pinValueDensity/100*pinValueSize/maximumGsize);
//gstssFaktorstill=1+((100-pinValueDensity)/100*pinValueSize/maximumGsize);
pinValueDensity/=100;
gstssFaktorspark=pinValueDensity;
gstssFaktorspark *= pinValueSize;
gstssFaktorspark /=maximumGsize;
gstssFaktorstill=(100 - pinValueDensity);
void fehlersuche()
Serial.print("Density: ");
Serial.print("Size: ");
Serial.print("Sparklingfaktor : ");
Serial.println(gstssFaktorspark);
Serial.print("Stillfaktor : ");
Serial.println(gstssFaktorstill);
Serial.print("maxSize : ");
Serial.println(maximumGsize);
That’s the result at the serial monitor
maxSize : 330
Density: 0
Sparklingfaktor : 0
Stillfaktor : 100
maxSize : 330
glass size ml is: 290
Density: 0
Sparklingfaktor : 0
Stillfaktor : 100
maxSize : 330
Density: 0
Sparklingfaktor : 0
Stillfaktor : 100
maxSize : 330
what can i do? I used also other spellings for calculation like /= or *=. Result was same.
regards sven
