C++ or python (on RPi)
https://pastebin.com/GSziWEds
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  =>          USB HOWTO: http://tiny.cc/BlynkUSB
  This sketch shows how to read values from Virtual Pins
  App project setup:
    Slider widget (0...100) on Virtual Pin V1
#define BLYNK_PRINT SwSerial
#define TRIGGER 9
#define ECHO    10
char auth[] = "YOUR AUTH TOKEN HERE";
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V5)
  // process received value
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
  pinMode(TRIGGER, OUTPUT);
  pinMode(ECHO, INPUT);
  long duration, distance;
  digitalWrite(TRIGGER, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGGER, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHO, HIGH);
  distance = (duration/2) / 29.1;
  Blynk.virtualWrite(V5, distance);
  delay(200);
i have a question, can i use this c++ code in raspberry pi? i cant find any python code to run the ultrasonic sensor with blynk apps.
Please post (formatted) code here as it is better for viewing than 3rd party links. I edited your post acordingly.
As for using that code… well, possibly, but you will have to figure out what changes to make in order to accommodate the WiringPi methods.
Python for Blynk is in Alpha stage… but there should be no reason you can’t find Ultrasonic sensor code in Python (Google is your friend :wink: ), and simply add in the Blynk library and required Blynk display and control options (well, depends on your Python experience :thinking:).
You can also look at using NodeJS on the RPi with Blynk.
thank you sir! will try that later
as for now, i found the python code to use value display widget on blynk.
but the problem is when i run the code, there is an error said that ;
----> ImportError : No module named ā€˜BlynkLib’
how can i solve this? :frowning_face:
these are the code that i run:
import BlynkLib
import time
BLYNK_AUTH = 'YourAuthToken'
# initialize Blynk
# register the task running every 3 sec
# (period must be a multiple of 50 ms)
def my_user_task():
    # do any non-blocking operations
    print('Action')
    blynk.virtual_write(2, time.ticks_ms() // 1000)
blynk.set_user_task(my_user_task, 3000)
# start Blynk (this call should never return)
blynk.run()
Did you install the library?
yes sir, i already installed the library using these command;
pip install blynk-library-python
Well… I can’t help you with Python, sorry.
I created a folder, installed the library, created the test script (even though I use Local Server)…
pi@raspberrypi:~ $ cd /home/pi/Blynk_Python
pi@raspberrypi:~/Blynk_Python $ pip install blynk-library-python
Collecting blynk-library-python
Installing collected packages: blynk-library-python
Successfully installed blynk-library-python-0.1.1
And the results from Thonny…
Python 3.5.3 (/usr/bin/python3)
>>> %Run UpTimeTest.py
Traceback (most recent call last):
  File "/home/pi/Blynk_Python/UpTimeTest.py", line 1, in <module>
    import BlynkLib
ImportError: No module named 'BlynkLib'
But it is beyond me… I can’t seem to find where BlynkLib.py even ā€œinstallsā€ too… in order to edit it for my Local Server use…
I don’t have the energy to pursue this myself… so I think I will stick with NodeJS :slight_smile:
its okay, thank you so much for the help sir! :slightly_smiling_face:
Well, I took another stab at it…
Found the file BlynkLib.py in /home/pi/.local/lib/python2.7/site-packages/ (on my system )
EDIT - And on my RPi3 it appears it is in /usr/local/lib/python2.7/dist-packages
And I found that if you open a Terminal CLI, go to that folder and type python, you get the Python prompt >>>
And finally, after copy/pasting the entire example sketch at that prompt, it tries to connect… now I don’t have my App set for Cloud, so I edited the BlynkLib.py file for what I think wat the proper method, but now it is getting all sorts of errors…
So until I do, I recommend you try the similar method as listed above, but using the default Cloud Server.
OK, using Cloud Server I was able to connect … and the Button on V1 shows CLI response, but nothing on the display Widget for uptime (EDIT - The widget needs to be set for 1 second reading frequency)…
But what a pain to get this far!!!.. somehow I don’t think this is the correct way :stuck_out_tongue:
pi@raspberrypi:~/.local/lib/python2.7/site-packages $ python
Python 2.7.13 (default, Nov 24 2017, 17:33:09)
[GCC 6.3.0 20170516] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import BlynkLib
>>> import time
>>> BLYNK_AUTH = '2c78d294e11xxxxxxxxxx19ac0361e2e'
>>> # Initialize Blynk
... blynk = BlynkLib.Blynk(BLYNK_AUTH)
>>> # Register Virtual Pins
... @blynk.VIRTUAL_WRITE(1)
... def my_write_handler(value):
...     print('Current V1 value: {}'.format(value))
>>> @blynk.VIRTUAL_READ(2)
... def my_read_handler():
...     # this widget will show some time in seconds..
...     blynk.virtual_write(2, time.ticks_ms() // 1000)
>>> # Start Blynk (this call should never return)
... blynk.run()
TCP: Connecting to blynk-cloud.com:80
Blynk connection successful, authenticating...
Access granted, happy Blynking!
Current V1 value: 1
Current V1 value: 0
Current V1 value: 1
Current V1 value: 0
Current V1 value: 1
Current V1 value: 0
And my ā€œfinalā€ :stuck_out_tongue: results…
Apparently I needed to run python2.7 in order to get mine to work from the script file in a normal CLI window…
pi@raspberrypi:~/Blynk_Python $ python2.7 UpTimeTest.py
Current V1 value: 1
Current V1 value: 0
Current V1 value: 1
Current V1 value: 0
Now onto trying to set it up for my Local Server… meanwhile this little python2.7 bit should have you up and running :wink:
And for Local Server, edit the BlynkLib.py file and find this line about midway down…
class Blynk:
    def __init__(self, token, server='blynk-cloud.com', port=None, connect=True, ssl=False):
…edit IP and port acordingly…
class Blynk:
    def __init__(self, token, server='xxx.xxx.xxx.xxx', port=8080, connect=True, ssl=False):
Quick addendum…
Install the Blynk library with THIS command and it will install in the Python 3.x version… then you can use Thonny to edit and run scripts. @vshymanskyy can you update your GitHub directions accordingly?
pip3 install blynk-library-python
That installed it in this directory in case you need to edit it for Local Server use…
/home/pi/.local/lib/python3.5/site-packages/
sir! i can now run the example code. :smile:
i found this on pi forum, they said that almost all code examples you find around the internet are for the python 2.x version. There’s different ways of coding in python 3.x and some examples wont run in it that ran in 2.x.
so i tried to run em’ on python 2.7 instead of python 3.5 and it works just like yours.
million thanks you for your help sir! :muscle:
Good to know… and too bad, I am liking how Thonny works… but it seems it needs Python 3.4 and later… guess I will try IDLE for Python 2.x
sir can i ask you few more questions?
i have these terminal widget example code run on my py 2 but there is error said;
AttributeError: 'module' object has no attribute 'dupterm'
and these are the code;
  Social networks:            http://www.fb.com/blynkapp
This example shows how to turn a Terminal widget into
the REPL console.
In your Blynk App project:
  Add a Terminal widget, bind it to Virtual Pin V5.
  Run the App (green triangle in the upper right corner).
import BlynkLib
import os
def hello():
    print('Welcome!')
# initialize Blynk
term = blynk.repl(5)
os.dupterm(term)
blynk.run()
Are you using the correct example? That doesn’t look like one of these…
EDIT forget it :blush: … I see now that you are using the 2nd one :stuck_out_tongue:
I have no idea… I am still working with the Up Time and trying to add in GPIO control of LEDs :smiley:
REPL example was targeting the WiPy hardware. It won’t work in linux atm. I’ll probably remove it at all :wink:
okay sir, thanks for all the help! :slightly_smiling_face:
okay sir noted.
