#19 - Modified Text Input Widget performance - Now with 100% more line feed
Well, here is another modification to make a widget work how I at least think it could (and possibly temporary… see my supplanted multi-coloured button above
The text Input widget is great… easy to use and compact, compared to the Terminal input option. Only one thing… It doesn’t act like a ‘true’ (IMHO) text input. No EOL, ‘carriage return’ or clearing upon hitting return. All by design? Perhaps
Well, here is my simple code mod to supply all those “missing” features
BLYNK_WRITE(V0) {
if (textIn.startsWith(" ")) { // If it has a leading SPACE...
textIn.remove(0, 1); // ...remove it.
if (textIn.endsWith(" ..")) { // If it has customisable EOL indicator, In my case SPACE and 2 PERIODS...
Blynk.virtualWrite(V0, " "); // "clear" the Text Input field. A null "" will not work, so needs a space
Serial.print(textIn); // Show string output as intended, or do whatever you want with the string.
Blynk.virtualWrite(vPin, textIn); // Like send it to a terminal Widget
To give this output…
BLYNK_WRITE(vPin) { // Button Widget
if (param.asInt()) {
Blynk.virtualWrite(vPin, "clr"); // Clears terminal if button state is 1
