#include <ESP8266mDNS.h> // For OTA
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
char auth[] = "xxxxxxxxxx"; // Local Server
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
//char server[] = "xxx.xxx.xxx.xxx"; // IP for your Local Server
char server[] = "blynk-cloud.com";
int port = 8080;
// DHT22 Sensor setup
#include <DHT.h>
#define DHTPIN 0 // GPIO0 - pin5 on ESP-01
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
float h;
float t;
// DS18B20 Sensor setup
#include <OneWire.h>
#include<DallasTemperature.h>
#define ONE_WIRE_BUS 2 // GPIO2 - pin3 on ESP-01
float DS18B20Temp;
DS18B20.begin();
Blynk.connect();
ArduinoOTA.setHostname("ESP-01 Multi-temp"); // For OTA
ArduinoOTA.begin(); // For OTA
void DS18B20TempSensor() // DS18B20 sensor reading
delay(500); // Yes, the evil delay... but only for a really short time every 10s . Alternative options are avail with timers.
void DHTTempHumSensor() // DHT sensor reading
h = dht.readHumidity();
Blynk.virtualWrite(V4, h);
Blynk.virtualWrite(V5, t);
BLYNK_WRITE(V1) { // Quick test read. Clears all values and reloads
if (param.asInt()) {
Blynk.virtualWrite(V0, 0);
Blynk.virtualWrite(V3, 0);
Blynk.virtualWrite(V4, 0);
Blynk.virtualWrite(V5, 0);
DS18B20TempSensor();
DHTTempHumSensor();
void UpTime()
Blynk.virtualWrite(V0, millis() / 1000);
ArduinoOTA.handle(); // For OTA
