I want my buzzer pin to turn high when my motion sensor(connected to a digital pin) turns high. I did a code without blynk and it is working but when I add blynk it doesnt work. I can see the motion sensor going high and low in the app but the buzzer pin remains in low/high state and it never makes a sound in the hardware.
int buzzerPin = D6;
int sensorPin = D7;
int sensorState = 0;
char auth[] = " uEv7YIPD4*******FABHqS89vaG9gjro";
char ssid[] = "King Mokoena";
char pass[] = "17071015";
void myTimerEvent()
{ pinMode (buzzerPin, OUTPUT);
pinMode (sensorPin, INPUT);
void callMacroSensor(){
digitalRead(sensorPin);
if (sensorPin == HIGH){
digitalWrite(buzzerPin, HIGH);
else{
digitalWrite(buzzerPin, LOW);
callMacroSensor();
int buzzerPin = D6;
int sensorPin = D7;
char auth[] = " uEv7YIPD4ytrrx9zFABHqS89vaG9gjro";
void myTimerEvent()
BlynkTimer timer2;
void TimerEvent()
//OWN LOOP
else{
timer.setInterval(1000L, TimerEvent);
timer2.run();
I fixed it, but it doesnt trigger the buzzer using the IF condition in arduino code, but when I use an event in the blynk app it works but the buzzer stays high
int buzzerPin = D6;
int sensorPin = D7;
void myTimerEvent()
Blynk.virtualWrite(V5, millis() / 1010);
BlynkTimer timer2;
void TimerEvent()
//OWN LOOP
sensorState=digitalRead(sensorPin);
if (sensorState == HIGH){
else{
digitalWrite(buzzerPin,LOW);
Blynk.virtualWrite(V5,sensorState / 2028);
timer2.run();
