Buying Energy Value
I will support Blynk by buying the energy value, appreciate your huge efforts you have put to create the app.
My question is: for example if I buy 10000 point and doing two small scale projects, Soil sensing and IMU manipulation.
I need to submit my project by 22nd May, is there a duration of how long I can use the purchased energy points?
Pls send your reply to my email, thank you.
Eugene puah
There is no time limit to the energy. However, if you don’t use your Blynk account for more than 6 months then your account will be deleted and your energy and projects will be lost.
Hi Pete,
Thanks for your early reply.
If I do my experiments daily for a month, will the energy reduces each day?
I think Blynk’s app is much simpler to use, almost straight forward.
Thank you very much and awaiting your next reply.
Eugene
Each widget that you add to a project from the widgetbox will use-up the amount of energy that is written next to the widget (200 for a button, 300 for a styled button etc).
If you delete a widget from your project then the energy is recycled and can be used again.
The only exception to this is the 1000 units needed to share a project. If you use this facility then the energy is not recycleable.
