Buttons not working when internet disconnected
Hi All,
Congratulations on your work. and Dear When i use
Blynk WIFI Manager for ESP8266/ESP32 lib for the below mention sketch
all the project works well when both wifi and blynk(internet access) connected but as soon as internet access end or blynk server disconnect the manual switch stop working. like
(esp8266) Connected (Wifi) Connected (Blynk Cloud Server or internet) for this condition below sketch works well when both wifi+internet connected or both disconnected
but When when i turn off the internet access only like
(esp8266) Connected (Wifi) DIS Connected (Blynk Cloud Server or internet) in this condition
the manual switch (or Push Button) stop working
Plz guide me in this regards i want the push buttons to work done even when internet access is not available or when not connected to blynk server
// define the GPIO connected with Relays and switches
#define RelayPin1 5  //D1
#define RelayPin2 4  //D2
#define RelayPin3 14 //D5
#define RelayPin4 12 //D6
#define SwitchPin1 10  //SD3
#define SwitchPin2 0   //D3
#define SwitchPin3 13  //D7
#define SwitchPin4 3   //RX
#define wifiLed   16   //D0
//Change the virtual pins according the rooms
#define VPIN_BUTTON_1    V1
#define VPIN_BUTTON_2    V2
#define VPIN_BUTTON_3    V3
#define VPIN_BUTTON_4    V4
int toggleState_1 = 1; //Define integer to remember the toggle state for relay 1
int toggleState_2 = 1; //Define integer to remember the toggle state for relay 2
int toggleState_3 = 1; //Define integer to remember the toggle state for relay 3
int toggleState_4 = 1; //Define integer to remember the toggle state for relay 4
int wifiFlag = 0;
#define AUTH "AUTH TOKEN"                 // You should get Auth Token in the Blynk App.
#define WIFI_SSID "Wifi Name"             //Enter Wifi Name
#define WIFI_PASS "Wifi Password"         //Enter wifi Password
void relayOnOff(int relay){
    switch(relay){
      case 1:
             if(toggleState_1 == 1){
              digitalWrite(RelayPin1, LOW); // turn on relay 1
              toggleState_1 = 0;
              Serial.println("Device1 ON");
             else{
              digitalWrite(RelayPin1, HIGH); // turn off relay 1
              toggleState_1 = 1;
              Serial.println("Device1 OFF");
             delay(100);
      break;
      case 2:
             if(toggleState_2 == 1){
              digitalWrite(RelayPin2, LOW); // turn on relay 2
              toggleState_2 = 0;
              Serial.println("Device2 ON");
             else{
              digitalWrite(RelayPin2, HIGH); // turn off relay 2
              toggleState_2 = 1;
              Serial.println("Device2 OFF");
             delay(100);
      break;
      case 3:
             if(toggleState_3 == 1){
              digitalWrite(RelayPin3, LOW); // turn on relay 3
              toggleState_3 = 0;
              Serial.println("Device3 ON");
             else{
              digitalWrite(RelayPin3, HIGH); // turn off relay 3
              toggleState_3 = 1;
              Serial.println("Device3 OFF");
             delay(100);
      break;
      case 4:
             if(toggleState_4 == 1){
              digitalWrite(RelayPin4, LOW); // turn on relay 4
              toggleState_4 = 0;
              Serial.println("Device4 ON");
             else{
              digitalWrite(RelayPin4, HIGH); // turn off relay 4
              toggleState_4 = 1;
              Serial.println("Device4 OFF");
             delay(100);
      break;
      default : break;
void with_internet(){
    //Manual Switch Control
    if (digitalRead(SwitchPin1) == LOW){
      delay(200);
      relayOnOff(1);
      Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);   // Update Button Widget
    else if (digitalRead(SwitchPin2) == LOW){
      delay(200);
      relayOnOff(2);
      Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);   // Update Button Widget
    else if (digitalRead(SwitchPin3) == LOW){
      delay(200);
      relayOnOff(3);
      Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);   // Update Button Widget
    else if (digitalRead(SwitchPin4) == LOW){
      delay(200);
      relayOnOff(4);
      Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);   // Update Button Widget
void without_internet(){
      delay(200);
      relayOnOff(1);
      delay(200);
      relayOnOff(2);
      delay(200);
      relayOnOff(3);
      delay(200);
      relayOnOff(4);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
  toggleState_1 = param.asInt();
  digitalWrite(RelayPin1, toggleState_1);
BLYNK_WRITE(VPIN_BUTTON_2) {
  toggleState_2 = param.asInt();
  digitalWrite(RelayPin2, toggleState_2);
BLYNK_WRITE(VPIN_BUTTON_3) {
  toggleState_3 = param.asInt();
  digitalWrite(RelayPin3, toggleState_3);
BLYNK_WRITE(VPIN_BUTTON_4) {
  toggleState_4 = param.asInt();
  digitalWrite(RelayPin4, toggleState_4);
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
  bool isconnected = Blynk.connected();
  if (isconnected == false) {
    wifiFlag = 1;
  if (isconnected == true) {
    wifiFlag = 0;
  pinMode(RelayPin1, OUTPUT);
  pinMode(RelayPin2, OUTPUT);
  pinMode(RelayPin3, OUTPUT);
  pinMode(RelayPin4, OUTPUT);
  pinMode(wifiLed, OUTPUT);
  pinMode(SwitchPin1, INPUT_PULLUP);
  pinMode(SwitchPin2, INPUT_PULLUP);
  pinMode(SwitchPin3, INPUT_PULLUP);
  pinMode(SwitchPin4, INPUT_PULLUP);
  //During Starting all Relays should TURN OFF
  digitalWrite(wifiLed, HIGH);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  timer.setInterval(3000L, checkBlynkStatus); // check if Blynk server is connected every 3 seconds
  Blynk.config(AUTH);
  if (WiFi.status() != WL_CONNECTED)
    //Serial.println("WiFi Not Connected");
    //+Serial.println("WiFi Connected");
    digitalWrite(wifiLed, LOW); //Turn on WiFi LED
  if (wifiFlag == 0)
    with_internet();
    without_internet();
I am very gratefull for the answer Thanks
Hi @Rizwan_Saeed
You’re posting in the wrong topic as your code has nothing to do with Blynk_WiFiManager library.
I suggest you ask @PeteKnight to move it to separate topic where many other users can help you out, certainly after you’ve done your basic research as this issue has been discussed and solved elsewhere in this forum.
Done!
@Rizwan_Saeed Search nonblocking or Blynk.config and Blynk.connect on this forum.
I have built a home automation system, the lights can be turned on / off from the blynk app, but also from physical buttons in the rooms. when the arduino is connected to the network, everything works fine and reliable (I can control the lights from my phone and also with the physical buttons).
the problem is, when the Arduino is not connected to the network.
(for example When internet is not available or not connected to Blynk server), the system is not working at all, i can not use the physical buttons without internet. and want to use physical button when no internet access.
I have been trying to solve this for a long time but the issue is not getting resolved.
Below is the basic Automation code for Plz help me in this regards in your precious time.
int wifiFlag = 0;
    switch(relay){
      case 1:
              toggleState_1 = 0;
             else{
              toggleState_1 = 1;
             delay(100);
      break;
      case 2:
              toggleState_2 = 0;
             else{
              toggleState_2 = 1;
             delay(100);
      break;
      case 3:
              toggleState_3 = 0;
             else{
              toggleState_3 = 1;
             delay(100);
      break;
      case 4:
              toggleState_4 = 0;
             else{
              toggleState_4 = 1;
             delay(100);
      break;
      default : break;
      delay(200);
      relayOnOff(1);
      delay(200);
      relayOnOff(2);
      delay(200);
      relayOnOff(3);
      delay(200);
      relayOnOff(4);
      delay(200);
      relayOnOff(1);
      delay(200);
      relayOnOff(2);
      delay(200);
      relayOnOff(3);
      delay(200);
      relayOnOff(4);
    wifiFlag = 1;
    wifiFlag = 0;
  Blynk.config(AUTH);
  if (wifiFlag == 0)
    with_internet();
    without_internet();
I think your problem is that you are checking to see if your WiFi is connected, rather than if you have a connection to the Blynk server.
Most routers will continue to provide a WiFi network in your home, even if you disconnect the incoming internet connection.
As a result, your without_internet routine only runs when the router is turned off, as opposed to when the router loses its connection to the outside world.
Read the documentation about Blynk.connected() - not to be confused with Blynk.connect or BLYNK_CONNECTED
Hi sir,
Problem is physical button not work when internet unavailable during this time nodemcu constantly try to connect to blynk server , I just want physical button to work without internet and when internet services back then connected to blynk automatically.
I suffering same to same problem of esp8226 and node mcu but i don’t find any solution. plz help me.
@Gmneamul please create a new “Need help with my project” topic, and provide ALL of the information that is requested when you do that.
