Hello guys,
I have an ATS / AMF project, I want to connect the Nextion ButtonDualState and the switches in Blynk to be used as a Manual and automatic operation. ButtonDualState which is in the nextion is functioning properly how to synchronize with the switches in Blynk …?
I already got a sketch example but it’s very different from my sketch structure .
I use the library itead arduino nextion
#include <PZEM004Tv30.h>
#include <Nextion.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include "RTClib.h"
#include "NexDualStateButton.h"
#include "NexButton.h"
#include "NexText.h"
#define RX2 16
#define TX2 17
SoftwareSerial HMISerial(18, 19); //Pin Nextion
const int PLNStatus = 27; // Status 220 AC
const int GENStatus = 14; //GenStatus
const int Stop = 26; //Stop Gen
const int Start = 25; //Start Gen
const int GEN = 33; //Relay Gen To Load
const int PLN = 32; //Relay 220 AC To Load
int Starting=0;
const int StartMan = 25; //Manual Operation
const int StopMan = 26;
const int Rst = 27;
uint32_t Selektor=0;
uint32_t Start1=0;
uint32_t Stop1=0;
int GenState; // voltage detection
int PlnState;
bool On=LOW;
bool Off=HIGH;
int AutoMode=0; //Switch case Auto
int ManualMode=0; //Switch case Manual
char HARI[7][12] = {"Ahad", "Senin", "Selasa", "Rabu", "Kamis", "Jum'at", "Sabtu"}; // Rtc
char buffer[100];
int energi;
PZEM004Tv30 pzem(&Serial2); //Pin PZEM
float voltage_blynk=0; //Monitoring Energy In Blynk
float current_blynk=0;
float power_blynk=0;
float energy_blynk=0;
float freq_blynk=0;
float Pf_blynk=0;
RTC_DS3231 rtc;
NexText V = NexText(1,3,"V"); //Nextion Energy
NexText A = NexText(1,5,"A");
NexText W = NexText(1,7,"W");
NexText Wh = NexText(1,9,"Wh");
NexText freq = NexText(1,11,"freq");
NexText Pf = NexText(1,21,"Pf");
NexText j = NexText(1,13,"j"); //Nextion Timer/RTC
NexText s = NexText(1,22,"s");
NexText tgl = NexText(1,16,"tgl");
NexText hari = NexText(1,19,"hari");
NexText bulan = NexText(1,23,"bulan");
NexText t5 = NexText(2,9,"t5");
NexText t2 = NexText(2,6,"t2");
NexText t8 = NexText(2,15,"t8");
NexDSButton Mode = NexDSButton(2,10,"Mode"); //selector in Nextion manual or Auto
NexDSButton Mstart = NexDSButton(2,11,"Mstart"); // Starting Gen in Nextion
NexDSButton Mstop = NexDSButton(2,12,"Mstop"); // StopGen in Nextion
NexButton Reset = NexButton(2, 17, "Reset"); // Reset Esp32 in Nextion
NexButton normal = NexButton(0, 14, "normal");
char auth[] = "xxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxx";
char pass[] = "Ixxxxxxx";
//Reset
NexTouch *nex_listen_list[] = {
&Reset,
&normal,
NULL
void ResetPopCallback(void *ptr) {
digitalWrite(Rst, LOW);
delay(500);
digitalWrite(Rst, HIGH);
void normalPopCallback(void *ptr) {
delay(100);
nexInit();
Serial2.begin(9600);
rtc.begin();
Reset.attachPop(ResetPopCallback, &Reset);
normal.attachPop(normalPopCallback, &normal);
pinMode(StartMan, OUTPUT); //Manual Output
pinMode(StopMan, OUTPUT);
pinMode(Stop, OUTPUT); //Auto Output Relay
pinMode(Start, OUTPUT);
pinMode(GEN, OUTPUT);
pinMode(PLN, OUTPUT);
pinMode(Rst, OUTPUT); //Reset
digitalWrite(Stop, Off);
digitalWrite(Start, Off);
digitalWrite(GEN, Off);
digitalWrite(Rst, Off);
pinMode(PLNStatus, INPUT_PULLUP); //Input Voltage Ac 220
pinMode(GENStatus, INPUT_PULLUP); //Input Voltage Gen
void Data(){
PlnState = digitalRead(PLNStatus);
GenState = digitalRead(GENStatus);
Mode.getValue(&Selektor);
Mstart.getValue(&Start1);
Mstop.getValue(&Stop1);
if (PlnState== On && GenState== Off)digitalRead(AutoMode=1);
if (PlnState== Off)digitalRead(AutoMode=2);
if (GenState== On && PlnState== Off)digitalRead(AutoMode=3);
if (GenState== On && PlnState== On)digitalRead(AutoMode=4);
if (Starting >=3)(AutoMode=5);
if(Start1==0 && Stop1==0)(ManualMode=1);
if(Start1==1 && Stop1==0)(ManualMode=2);
if(Start1==0 && Stop1==1)(ManualMode=3);
if(Start1==1 && Stop1==1)(ManualMode=3);
void Change_Over(){
if (Selektor==0){
t5.setText(": Auto");
switch (AutoMode) {
case 1:
delay(3000);
digitalWrite(PLN, On);
t2.setText(": PLN");
t8.setText(": Off");
digitalWrite(StartMan,Off);
digitalWrite(StopMan,Off);
break;
case 2:
digitalWrite(Stop, On);
delay(3000);
Starting++;
digitalWrite(Start, On);
t8.setText(": Starting");
delay(4000);
t8.setText(": Ready");
break;
case 3:
delay(10000);
digitalWrite(PLN, Off);
digitalWrite(GEN, On);
t2.setText(": Genset");
t8.setText(": On");
break;
case 4:
delay (5000);
break;
case 5:
t8.setText(": Gagal Starting");
break;
default:
break;
Blynk.virtualWrite(V7, Off);
Blynk.virtualWrite(V8, Off);
else if(Selektor==1){
t5.setText(": Manual");
switch(ManualMode){
case 1:
digitalWrite(StartMan, HIGH);
digitalWrite(StopMan, LOW);
delay(1);
break;
case 2:
digitalWrite(StartMan, LOW);
delay(1);
break;
case 3:
digitalWrite(StopMan, HIGH);
delay(1);
break;
default:
break;
void Energy() {
float voltage = pzem.voltage();
if (voltage >= 0.0){
itoa(voltage, buffer, 10);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
V.setText (buffer);}
else{
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
V.setText ("0");
float current = pzem.current();
if (current >= 0.0){
itoa(current, buffer, 10);
A.setText (buffer);}
else{
A.setText ("0");
float power = pzem.power();
if (power >= 0.0){
itoa(power, buffer, 10);
W.setText (buffer);}
else{
W.setText ("0");
float energy = pzem.energy();
energi=energy*1000;
if (energi >= 0.0){
itoa(energi, buffer, 10);
Wh.setText (buffer);}
else{
Wh.setText ("0");
float frequency = pzem.frequency();
if (frequency >= 0.0){
itoa(frequency, buffer, 10);
freq.setText (buffer);}
else{
freq.setText ("0");
float pf = pzem.pf();
if (pf >= 0.0){
itoa(pf, buffer, 10);
Pf.setText (buffer);}
else{
Pf.setText ("0");
void RTC() {
DateTime now = rtc.now();
int Tahun = now.year();
int Bulan = now.month();
int Tanggal = now.day();
int Jam = now.hour();
int Menit = now.minute();
int Detik = now.second();
int Suhu = rtc.getTemperature();
sprintf(buffer, "%02d:%02d:%02d", Jam, Menit, Detik);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
j.setText (buffer);
sprintf(buffer, "%s,", HARI[now.dayOfTheWeek()]);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
hari.setText (buffer);
sprintf(buffer, "%02d'C", Suhu);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
s.setText (buffer);
sprintf(buffer, "%02d/%02d/%02d", Tanggal, Bulan, Tahun);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
tgl.setText (buffer);
delay(100);
void Android(){
float v = pzem.voltage();
if (v >= 0.0){voltage_blynk=v;}
float i = pzem.current();
if(i >= 0.0){current_blynk=i;}
float w = pzem.power();
if(w >= 0.0){power_blynk=w;}
float KWh = pzem.energy();
if(KWh >= 0.0){energy_blynk=KWh*1000;}
float Hz = pzem.frequency();
if(Hz >= 0.0){freq_blynk=Hz;}
float pF = pzem.pf();
if(pF >= 0.0){Pf_blynk=pF;}
Blynk.virtualWrite(V0, voltage_blynk, " V");
Blynk.virtualWrite(V1, current_blynk, " A");
Blynk.virtualWrite(V2, power_blynk, " W");
Blynk.virtualWrite(V3, energy_blynk, " Wh");
Blynk.virtualWrite(V4, freq_blynk, " Hz");
Blynk.virtualWrite(V5, Pf_blynk);
else if (Selektor == 0) {
Change_Over();
BLYNK_WRITE(V7) {
Start1 = param.asInt();
Change_Over();
BLYNK_WRITE(V8){
Stop1 = param.asInt();
Change_Over();
Data();
Change_Over();
Android();
Energy();
RTC();
nexLoop(nex_listen_list);
