hi guys
i’m using WEMOS D1 mini pro board.
i added button switch widget on my blynk app.
i run the app from my iPhone 7 and from my LG G3.
only my iPhone can toggle the state of the pin, when i do it on my LG G3 state will not toggle, or other words the button
isn’t working on my LG G3
i re installed blynk app on my LG G3 but didn’t help
appreciate any help
thanks
eli
Generally things work better with Android than iOS as the latter is missing some functionality.
Can we see your sketch and Serial Monitor?
Hello. We have the issue with PWM pins in the latest Android release. Working on fix.
thanks but the issue is with the Android , not iPhone :).
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "ggggggggggggg";
char ssid[] = "rtrtrt";
char pass[] = "xxxx";
WidgetLED led1(V1);
WidgetRTC rtc;
// V1 LED Widget is blinking
void blinkLedWidget()
if (led1.getValue()) {
led1.off();
Serial.println("LED on V1: off");
led1.on();
Serial.println("LED on V1: on");
rtc.begin();
I know that, I was just commenting that’s it’s rare for Android to be worse than iOS.
Looks like Blynk are working on a bug fix for Android.
@elibt do you have the button tied to a real pin as they don’t appear in your sketch?
@Dmitriy should Virtual pins work OK?
yes.
thanks a lot
yes, the virtual pin works on both iPhone and android
i tied the switch to 3 different pins each time (D5,D6,D7) and i measured with DVM the output voltage
when i used my iPhone i saw it goes to 3.3V when pressed on and goes to 0V when pressed off.
when used android the voltage didnt change, stayed at 0V
many thanks
eli
We had released a fix for PWM button issue. It should be available to download soon.
thx
