Hello!
Help me with the problem: there is a code
BLYNK_WRITE(V1) { // Called whenver setting Time Input Widget
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
void TimeCheck() { // call with timer every 30 seconds or so
// Get RTC time
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
Serial.print("Current Time: ");
Serial.println(currentTime);
// Get Time Input Widget time
sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec);
Serial.print("Start Time: ");
Serial.println(startTime);
sprintf(startTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec);
Serial.print("Stop Time: ");
if (hour() == SThour) {
if (minute() == STmin) {
Serial.println("Doing something now");
digitalWrite(RELE, LOW); // Π²ΠΊΠ»ΡΡΠ°Π΅ΠΌ ΡΠ΅Π»Π΅
Blynk.setProperty(V4, "offLabel", "");
led1.on();// Π²ΠΊΠ»ΡΡΠ°Π΅ΠΌ ΠΏΠΎΠ΄ΡΠ²Π΅ΡΠΆΠ΄Π°ΡΡΡΡ Π»Π°ΠΌΠΏΠΎΡΠΊΡ
} else if (minute() < STmin) {
Serial.println("Will do something");
} else if (minute() > STmin) {
Serial.println("Did something");
Serial.println("Clueless");
if (hour() == SPhour) {
if (minute() == SPmin) {
Serial.println("Stopping something now");
digitalWrite(RELE, HIGH); // ΠΎΡΠΊΠ»ΡΡΠ°Π΅ΠΌ ΡΠ΅Π»Π΅
Blynk.setProperty(V4, "onLabel", "");
led1.off();// Π²ΡΠΊΠ»ΡΡΠ°Π΅ΠΌ Π»Π°ΠΌΠΏΠΎΡΠΊΡ
} else if (minute() < SPmin) {
Serial.println("Will stop something");
} else if (minute() > SPmin) {
Serial.println("Stopped something");
Serial.println("----------");
BLYNK_WRITE(V4) {
// int buttonState = param.asInt();
rele = param.asInt();
digitalWrite(RELE, rele);
if (rele == 0) {//ΠΏΡΠΎΠ²Π΅ΡΠΈΠΌ ΡΠΎΡΡΠΎΡΠ½ΠΈΠ΅.
led1.on(); //Π²ΠΊΠ» Π²ΠΈΡΡ.ΡΠ²Π΅ΡΠΎΠ΄ΠΈΠΎΠ΄
else { //ΠΈΠ½Π°ΡΠ΅ Π²ΡΠΊΠ»ΡΡΠΈΠΌ
led1.off();
In it relay can be turned on both through Time Widget and Button Widget. I made sure that the led shows the status of the relay (on/off) but I do not know how to make the state of the button displays the current state of the relay. I mean, if the relay is turned on using the Time Widget button should change its state. Is it possible to implement this?
Thanks!
