Hello all.
Very new to Blynk and a bit of a noob in Arduino overall but have gotten this far!
Issue i am having is that sometimes pressing the button in the app doesn’t activate the virtual pin.
Is there some sort of feedback that can be added to the button so if the command doesn’t work it doesn’t change status?
Have updated code to run digital reads less often.
Appears to have helped but still missing app commands on occasion.
http://twitter.com/blynk_app
Note: This only works on Android!
iOS does not support Bluetooth 2.0 Serial Port Profile
You may need to pair the module with your smartphone
via Bluetooth settings. Default pairing password is 1234
NOTE: Bluetooth support is in beta!
This example shows how to send values to the Blynk App,
when there is a widget, attached to the Virtual Pin and it
is set to some frequency
Project setup in the app:
Value Display widget attached to V5. Set any reading
frequency (i.e. 1 second)
char auth[] = "a94873fa64d64471bed7c10775a21f34";
BlynkTimer timer; // Announcing the timer
SoftwareSerial SerialBLE(10, 11); // RX, TX
//Assign inputs to wanted Arduino pins here
const int VVTpin = 7;
const int FPin = 8;
//Assign outputs to wanted Arduino pins here
const int mainrelay = 2;
const int starter = 3;
const int FPout = 4;
const int headlight = 5;
//initialise input state
unsigned long onPauseMillis = 0;
unsigned long currentMillis;
int starterrelaystate = 0;
int mainrelaystate = 0;
int headlightstate = 0;
int pause = 0;
//setup timer for starter to be ran before cancel
const unsigned long OnTime = 5000;
const unsigned long PauseTime = 2000;
void engineon()
{ //Engine on command from App:
mainrelaystate = HIGH;
digitalWrite(mainrelay, mainrelaystate);
onPauseMillis = currentMillis;
pause = HIGH;
void engineoff()
{ //Engine off command from App:
pause = LOW;
mainrelaystate = LOW;
digitalWrite(mainrelay, LOW);
digitalWrite(starter, LOW);
digitalWrite(headlight, LOW);
digitalWrite(FPout, LOW);
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
int pinValue = param.asInt();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
if (pinValue == 1) // if Button sends 1
engineon();
engineoff();// start the function
void enginestart()
{ //Engage starter motor:
pause = LOW;
starterrelaystate = HIGH;
digitalWrite(starter, starterrelaystate);
void killstarter()
{ //Kill Starter function
pause = LOW;
starterrelaystate = LOW;
void headlighton()
{ digitalWrite(headlight, HIGH);
void readInputs()
//Kill starter motor once engine running:
if ((digitalRead(VVTpin) == LOW) && (mainrelaystate == HIGH))
killstarter();
//Starter Motor control:
currentMillis = millis(); // Remember the current time and turn off starter after timer complete:
if (((starterrelaystate) == HIGH) && (currentMillis - previousMillis >= OnTime))
killstarter();
//Pause on power up before engaging starter motor
if (((pause) == HIGH) && (currentMillis - onPauseMillis >= PauseTime) && (mainrelaystate == HIGH))
enginestart();
//Fuelpump relay control:
if ((digitalRead(FPin) == LOW) && (mainrelaystate == HIGH))
digitalWrite(FPout, HIGH);
//Headlight control:
if ((digitalRead(FPin) == LOW) && (digitalRead(VVTpin) == LOW) && (mainrelaystate) == HIGH)
headlighton();
timer.setInterval(250L, readInputs); //timer will run every sec
SerialBLE.begin(115200);
Blynk.begin(SerialBLE, auth);
/*Set Assigned pins to be either an input or an output*/
pinMode(VVTpin, INPUT_PULLUP);
pinMode(FPin, INPUT_PULLUP);
pinMode(mainrelay, OUTPUT);
pinMode(starter, OUTPUT);
pinMode(FPout, OUTPUT);
pinMode(headlight, OUTPUT);
timer.run(); // run timer every second
