In my setup I have the following parts:
local blynk server
flashed sonoff controlling a light
blynk app with a button
python program running on an RPI
The blynk app has a button that controls the light attached to the sonoff. This works without a problem. In the python program I wish to see the state of the light (mirroring the button in the blynk app) as well as change the light. As a test I have made a small program that changes the light every 5 seconds, see below.
If I change the light with the app button, the light actually changes via the sonoff device and I get a notification via the write_handler in the python program. But if I change the light from the python program via virtual_write, the button in the blynk app does change, but the actual light does not change. How can I make the sonoff actually change the light when I change it in the python program? Additionally, I had expected the read_handler function to be called from the blynk server, but it is never called, why?
import blynklib
import threading
blynk = blynklib.Blynk("My token", server='My local server', port=8080, heartbeat=15)
current_state = 0
# This works, but only for the button in the app, not the actual light attached to pin V2 of the Sonoff
def change_button():
global current_state
global blynk
if current_state == 0:
current_state = 1
else:
current_state = 0
blynk.virtual_write(2, current_state)
# restart the timer
timer = threading.Timer(5.0, change_button)
timer.start()
# This function is never called
@blynk.handle_event("read V2")
def read_handler(vpin):
print('read_handler')
# This works
@blynk.handle_event("write V2")
def write_handler(pin, value):
print('state of V2 is set to ', value)
current_state = value
# just a timer to make the button change every 5 seconds
timer.start()
while True:
blynk.run()
