I was wondering if someone else also experienced or can replicate a bug in the Timer widget, using the latest IOS App?
When I set the hour value to 1 (o’clock) and acknowledge the widget the timer is ether changed to 0 or 2 (o’clock). It alternates between the 0 and 2 value. Both Start and Stop time are effected. The minutes and seconds don’t have this issue and all other values used in the hour value seem to work correctly.
I didn’t understand how to reproduce it. Could you please make a step-by-step description of your actions and what’s happening. Screenshots would be helpful as well.
Sorry for the late response. Although I’ve rebooted the App and even my phone that day, I couldn’t solve the issue. However since the day after the issue seems to be solved. I don’t know what might be de cause of that but I’ll have a sneaking suspicion winter daytime savings could be a possible cause. Anyway, problem solved I guess.
