I’m using iphone 5s. I connect esp8266 module to arduino mega board as exactly on blynk tutorial and used sample code “LED Blink” in Blynk example browser. but when i run it, everything fine untill esp8266 connect to my personel hotspot. after that " Buffer overflow " appeared in serial monitor my phone indicated that device is offline. But everythink work fine in android devices.
WARNING!
It's very tricky to get it working. Please read this article:
Blynk using a LED widget on your phone!
App project setup:
LED widget on V1
#include <ESP8266_Lib.h>
char auth[] = "04ff75de571e4a11832fe65c9a98f195"/*"cffec781a9754881835c45beb9429996"*/;
char ssid[] = "Emperor_Rukz"/*"J7 Pro"*/;
char pass[] = "sachin27290"/*"12345678"*/;
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
WidgetLED led1(V1);
// V1 LED Widget is blinking
void blinkLedWidget()
if (led1.getValue()) {
led1.off();
Serial.println("LED on V1: off");
led1.on();
Serial.println("LED on V1: on");
// Set ESP8266 baud rate
