First i controled a led using blynk it worked fine but when i added two more sensor Buffer over flow problem started is there any solution .(I am using ARDUINO uno AND ESP8266)
#include <ESP8266_Lib.h>
#include <DHT.h>
char auth[] = "a9********";
char ssid[] = "*********";
char pass[] = "********";
//#define EspSerial Serial1
SoftwareSerial EspSerial(2, 3); // TX,RX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
#define DHTPIN 5 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
//rpm
int irpin=5;
int enter=0;
//switch
// Set your LED and physical button pins here
const int ledPin = 7;
const int btnPin = 8;
void checkPhysicalButton();
int ledState = LOW;
int btnState = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V2);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V2) {
ledState = param.asInt();
digitalWrite(ledPin, ledState);
if (digitalRead(btnPin) == LOW) {
if (btnState != LOW) {
// Toggle LED state
ledState = !ledState;
// Update Button Widget
btnState = LOW;
btnState = HIGH;
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
dht.begin();
//switch
pinMode(ledPin, OUTPUT);
pinMode(btnPin, INPUT_PULLUP);
//rpm
pinMode(irpin,INPUT);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
int c,i,count=0,rpm,v;
for(i=0;i<=1000;++i)
c=analogRead(irpin);
if(c<400)
enter=1;
if ( (c>400)&& (c>v)&& (enter==1))
count++;
enter=0;
delay(1);
v=0;
rpm=count*53.5;
Blynk.virtualWrite(V7, rpm);
