jperez
1
when working with a virtual pin loop, the input works but when leaving it disconnects from blynk
BLYNK_WRITE(V1)
int Estado_Alarma = param.asInt();
if (Estado_Alarma == 0)
do
digitalWrite(13, HIGH);
while (Estado_Alarma != 0);
digitalWrite(13, LOW);
I would not use a do while loop as it is blocking. Does the pi really need to be continuously set? Why not just the if statement?
int Estado_Alarma;
timer.setInterval(2000L, EstadoAlarma );
void EstadoAlarma() {
}else{
BLYNK_WRITE(V1)
jperez
4
Excelent,
Thank you very much for the help
You could also try:
BLYNK_WRITE(V1)
digitalWrite(13, !param.asInt());
You are the best @JustBertC
