Brushless Motor controlling using ESC
I am using NODEMCU, ESC -30A, 930kv outrunner bldc motor,
i just need to control the speed of my motor, but it doesn’t working in that way, the motor starts beeping with some interval continuously,
Here is my code,
Follow us:                  http://www.fb.com/blynkapp
                            http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
GitHub - esp8266/Arduino: ESP8266 core for Arduino
Please be sure to select the right ESP8266 module
in the Tools → Board menu!
Change WiFi ssid, pass, and Blynk auth token to run :slight_smile:
Feel free to apply it to any other example. It’s simple!
#include <Servo.h>
char auth[] = "edDzhlUNKOJ2_h6dkb_wC0-Rh7toX2t1";
char ssid[] = "MyNetwork";
char pass[] = "password";
Servo ESC;
  ESC.attach(2,1000,2000);//Pin Number D4
  ESC.writeMicroseconds(1000);
BLYNK_WRITE(V2){
  int pinValue = param.asInt();
  pinValue = map(pinValue, 0, 1023, 0, 180);
  ESC.write(pinValue);
  ESC.writeMicroseconds(pinValue);
  Blynk.virtualWrite(V1, pinValue);
  Serial.print("V2 Slider Value is: ");
  Serial.println(pinValue);
//This is my code
//Please help me if anyone knows what is wrong?
@Phani please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code, so that it displays correctly.
Copy and paste these characters if you can’t find the correct character on your keyboard.
Thank you Sir, done what you said…
