Hi Blynkers,
I am working on a project that will control the temperature of a “box” that will go up to 65ºC.
I will use the Wemos Mini D1 and several sensors/acuators, and a 40w bulb as heater (yes, only 40w…)
(In a few weeks I will be able to share the project with all of you providing more details)
I will add other Wemos mini D1 with a db18b20 to control the other board, this way, if the main WeMos goes out of control for whatever reason, the second board will turn off all the equipment (Safety first…)
I want to control the main board and the second one with the same dashboard, so, I’m wondering the best solution from stability point of view. I can use Bridge function or use the same Token with different Vpins.
Many thanks @Pavlo,
I know they both will work… I’m not so newbie with Blynk , BUT, I’m wondering the advantage to send all the commands to both boards since I want to keep the second board as “free” as maximum to avoid disconnections.
Reading my own comment… I think I will go to Bridge function… Anyway, thanks for your advise, really appreciated!!
Too slow @Dmytro… I already have deleted the project for the Wemos and rebuilt the code using same Token… sorry…
Do you really want to review it? If you want I can do it again… but not today…. Let me know…
