I can’t make the BRIDGE work, someone can be kind enough to tell me what’s wrong with this sketch. The main idea is to make PIN 13 work in LOW and HIGH of the second (B or 2) device. This code is in the device (A or 1)
#define BLYNK_PRINT Serial //Comente esto para desactivar impresiones y ahorrar espacio
//Su authtoken generado por la aplicacion Blynk
char auth[] = “Token 1 device, send”; //Esp8266 V3
WidgetBridge bridge1(V1);
BLYNK_CONNECTED() {
bridge1.setAuthToken(“Token 2 device, catcher”); // Autotoken de la Tiny principal- Esp8266 NodeMCU
char ssid[] = “XXXXXXXXXXX”; //Nombre de la red WIFI
char pass[] = “XXXXXXXXXXX”; //contraseña de la red WIFI
pinMode(5,OUTPUT);
}//End Setup()
void Send(){
int PIND1 = digitalRead(5);
if (PIND1==1)
bridge1.digitalWrite(13,LOW);
bridge1.digitalWrite(13,HIGH);
}// end Send()
Send();// llama a ejecutar la función
