At last there is WHITE SMOKE. It is necessary to have some code at the receiving end of the bridge to catch the incoming messages. (like in Roffey’s example)
The new code in the receiving side is:
BLYNK_WRITE(V21)
int slidV21val = param.asInt();
Blynk.virtualWrite(24,slidV21val);
BLYNK_WRITE(V22)
int slidV22val = param.asInt();
Blynk.virtualWrite(23,slidV22val);
My code for the transmitting side is:
char auth[] = “054d0c9abdad4ea79999464132ec3b7a”;
WidgetBridge bridge1(V30); //Bridge widget on virtual pin v30
bool aanuit = false;
bool aanuit1 = false;
int val = 0;
int val1 =1024 ;
WidgetLED led13(V13);
WidgetLED led14(V14);
WidgetLED led15(V15);
delay(5000);
Serial.println(“Start”);
Blynk.begin(auth, “JOKER”, “???”);
// Wait until connected
bridge1.setAuthToken(“967741c612dc4706mxmxmb4a5517023470241”);
timer.setInterval(5000L, knipper);
timer.setInterval(2000L, knipper1);
yield();
void knipper() {
val++;if (val==1023){val=0;}
if (aanuit == true) {
led15.on();bridge1.digitalWrite(2,HIGH);bridge1.virtualWrite(V22,val);aanuit=false;}
else{led15.off();bridge1.digitalWrite(2,LOW);bridge1.virtualWrite(V22,val);aanuit=true;}
void knipper1() {
val1–; if (val1==0) {val1=1023;}
if (aanuit1 == true) {
led14.on();bridge1.digitalWrite(5,HIGH);bridge1.virtualWrite(V21,val1);aanuit1=false;}
else{led14.off();bridge1.digitalWrite(5,LOW);bridge1.virtualWrite(V21,val1);aanuit1=true;}
My code for the receiving side is:
char auth[] = “967741c612dc4706b4asss5517023470241”;
delay(5000);
//bridge1.setAuthToken(“967741c612dc4ddd706b4a5517023470241”);
timer.setInterval(500L, knipper);
timer.setInterval(1000L, knipper1);
yield();
BLYNK_WRITE(V20)
BLYNK_WRITE(V21)
Serial.print("slider val v21 = ");
Serial.println(slidV21val);
BLYNK_WRITE(V22)
Serial.print("slider val v22 = ");
Serial.println(slidV22val);
void knipper() {
led15.on();aanuit=false;}
else{led15.off();aanuit=true;}
void knipper1() {
led14.on();aanuit1=false;}
else{led14.off();aanuit1=true;}
