hello ,
I am creating a motion detector with a PIR module connected to an ESP8266. And I would like my lamp also controller with an ESP8266 to be activated when a movement is detected. Only when a movement is detected nothing happens on the second device yet the movement is detected on the first device
here is the motion sensor code:
You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- ESP8266 board
example.
#define BLYNK_TEMPLATE_ID "--"
#define BLYNK_DEVICE_NAME "--"
#define BLYNK_AUTH_TOKEN "Auth Token A"
const int pirPin = D0;
bool pirStatus = false;
int timerr = 0;
char ssid[] = "---";
char pass[] = "---";
WidgetBridge bridge1(V0);
pinMode(pirPin, INPUT);
timer.setInterval(1000L, myTimer);
bridge1.setAuthToken("Auth Token B");
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
Blynk.virtualWrite(V2, pirStatus);
Blynk.virtualWrite(V5, timerr);
pirStatus = digitalRead(pirPin);
void myTimer()
timerr = timerr+1;
if(pirStatus == 0 && timerr >= 20){
bridge1.virtualWrite(V24, 1);
Blynk.virtualWrite(V1, 1);
bridge1.virtualWrite(V24, 0);
Blynk.virtualWrite(V1, 0);
if(pirStatus == 1){timerr = 0;}
and here is the lamp sensor code :
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
#define BLYNK_TEMPLATE_ID "---"
#define BLYNK_DEVICE_NAME "---"
#define BLYNK_AUTH_TOKEN "---"
#include <FastLED.h>
#define NUM_LEDS 80
int R;
int G;
int B;
int STATE;
int bright;
CRGBArray<NUM_LEDS> leds;
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char auth[] = "---";
char pass[] = "--";
FastLED.addLeds<WS2811,D0,RGB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
bright = 255;
BLYNK_WRITE(V1){STATE = param.asInt();if(STATE==1){FastLED.setBrightness(bright);}else{FastLED.setBrightness(0);}FastLED.show();}
BLYNK_WRITE(V5){bright = param.asInt();if(STATE==1){FastLED.setBrightness(bright);}FastLED.show();}
BLYNK_WRITE(V9){ R = param[0].asInt(); G = param[1].asInt(); B = param[2].asInt();for(int i = 0 ; i <= NUM_LEDS ; i++){leds[i] = CRGB(R,G,B);FastLED.show();}}
BLYNK_WRITE(V24){
int pinData = param.asInt();
Serial.print(pinData);
I modified the code so that it sends the information by serial port and not that it turns on the light
Thanks to anyone who takes the time to respond.
