Both sliders will work once then stop
The software below is to control 2 stepper motors on my Telescope for the main focuser and the autoguider scope. I’m using an old laptop to USB link to the Arduino Uno. along with a DHT 11 for temperature, Humidity and dew point. I have no problems linking the Arduino to my IPhone I can control the stepper motor enable inputs and get the temperature data without any issues. However both sliders V10 and V11 will move the motors up to a minute later then nothing. Below is the software any advise would be appreciated
 #include  <Blynk.h>
 #include  <SoftwareSerial.h>
 #include  <AccelStepper.h>
 #include  <MultiStepper.h>
 #include  <DHT.h>
int long newvalst1 = 0;   //new value stepper 1
int long newvalst2 = 0;   //new value stepper 2
float focuserst1 = 0.0;   //actual value stepper 1 mm
float focuserst2 = 0.0;   //actual value stepper 2 mm
int st1onoff = 0;         //stepper 1 enable on/off
int st2onoff = 0;         //stepper 2 enable on/off
int coolingfan = 0;       //cooling fan
// The X Stepper pins
 #define STEPPER1_DIR_PIN 4
 #define STEPPER1_STEP_PIN 5
// The Y stepper pins
 #define STEPPER2_DIR_PIN 7
 #define STEPPER2_STEP_PIN 6
AccelStepper stepper1(AccelStepper::DRIVER, STEPPER1_STEP_PIN, STEPPER1_DIR_PIN);
AccelStepper stepper2(AccelStepper::DRIVER, STEPPER2_STEP_PIN, STEPPER2_DIR_PIN);
//*********************************************Setup Dew Point Calculations
double dewPoint(double celsius, double humidity)
  // (1) Saturation Vapor Pressure = ESGG(T)
  double RATIO = 373.15 / (273.15 + celsius);
  double RHS = -7.90298 * (RATIO - 1);
  RHS += 5.02808 * log10(RATIO);
  RHS += -1.3816e-7 * (pow(10, (11.344 * (1 - 1 / RATIO ))) - 1) ;
  RHS += 8.1328e-3 * (pow(10, (-3.49149 * (RATIO - 1))) - 1) ;
  RHS += log10(1013.246);
  // factor -3 is to adjust units - Vapor Pressure SVP * humidity
  double VP = pow(10, RHS - 3) * humidity;
  // (2) DEWPOINT = F(Vapor Pressure)
  double T = log(VP / 0.61078); // temp var
  return (241.88 * T) / (17.558 - T);
//******************************************** Include Section
char auth[] = "84b261deea7843cdb57e93acc4b18260";
//********************************************** Setup Blynk_WRITE
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V10) { //Main focuser slider value
 newvalst1 = param.asInt();
   stepper1.runToNewPosition(newvalst1);  // Move stepper to new position
    Blynk.syncVirtual(V10);
     focuserst1 = newvalst1 * (30.0 / 1023.0);
   Blynk.virtualWrite(V20, focuserst1);
   Blynk.virtualWrite(V21, newvalst1);
terminal.flush();
BLYNK_WRITE(V11) {  //autoguider focuser slider value
   newvalst2 = param.asInt();
    stepper2.runToNewPosition(newvalst2);  // Move stepper to new position
     Blynk.syncVirtual(V11);
      focuserst2 = newvalst2 * (60.0 / 1023.0);
   Blynk.virtualWrite(V3, focuserst2);
  Blynk.virtualWrite(V2, newvalst2);
terminal.flush();
BLYNK_WRITE(V15) // main focuser stepper enable on/off
  st1onoff = param.asInt();
  terminal.flush();
BLYNK_WRITE(V16) //autoguider stepper enable on/off
  st2onoff = param.asInt();
  terminal.flush();
//*************************************** Setup Stepper Motors
 #define stpren1 8  //pin 7 Main Focuser Stepper Enable 1
 #define stpren2 12  //pin 9 Auto Guider Stepper Enable 2
 #define DHTPIN A0  //pin A0 DHT11 Temperature Sensor
 #define fan 2     // pin 2 Telescope cooling Fan
DHT dht(DHTPIN, DHTTYPE);
//***************************************** Variables to store current, previous and move position
    SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
   // This will print Blynk Software version to the Terminal Widget when
    // your hardware gets connected to Blynk Server
    terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
    terminal.println(F("-------------"));
    terminal.println(F("Arduino Connected to Iphone"));
    terminal.flush();
    dht.begin();
    stepper1.setMaxSpeed(500);  // Set speed fast enough to follow pot rotation
    stepper1.setAcceleration(400);  //  High Acceleration to follow pot rotation
   stepper2.setMaxSpeed(500);
    stepper2.setAcceleration(400);
   pinMode(stpren1, OUTPUT);     //enable stepper 1
    pinMode(stpren2, OUTPUT);     //enable stepper 2
    pinMode(fan, OUTPUT);         //cooling fan for telescope
    stepperenables();
    dewreading();
void dewreading() {
delay (5000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius
  float f = dht.readTemperature(true);
  // Compute heat index
  // Must send in temp in Fahrenheit!
  float hi = dht.computeHeatIndex(f, h);
  float hiDegC = dht.convertFtoC(hi);
  Blynk.virtualWrite(V0, t, 1);
  Blynk.virtualWrite(V7, h);
  Blynk.virtualWrite(V6, dewPoint(t, h));
 if (h > 70){
   digitalWrite(fan, HIGH);
 if (h < 65){
   digitalWrite(fan, LOW);
void stepperenables() {
  if (st1onoff == true) {
    digitalWrite(stpren1, HIGH);   //Stepper 1 Enable ON
  if (st1onoff == false) {
    digitalWrite(stpren1, LOW);     //Stepper 1 Enable OFF
  if (st2onoff == true) {
    digitalWrite(stpren2, HIGH);   //Stepper 2 Enable ON
  if (st2onoff == false) {
    digitalWrite(stpren2, LOW);   //Stepper 2 Enable OFF
before answering for your question, please format your code properly!
@Andybee You didn’t format your code correctly as requested and shown. I have corrected it for you. Please look back and see how it is done for the future. Thanks.
@wanek nice diagram :wink: (I replaced it with a current one, the previous one had a typo, my bad :blush: )
@Andybee you have a rather long delay that will basicly halt your entire program for the duration… probably the only reason you are not loosing full connection is because of the USB link; Same delays with a WiFi MCU would have you disconnecting all the time.
Change out the delays and use timer functions instead.
http://docs.blynk.cc/#blynk-firmware-blynktimer
also, it seems to me that you are not using the {} correctly. you have some extra brackets in setup and loop functions.
Thank you updating. I have adjusted the program to a timer from the delay. Cleaned up the program, Although there is an improvement it still stutters. Would there be any benefit to convert to a local server.!
Sure it would.
An increase in response time.
Also full freedom do edit settings and unlimited energy
Check these response times and guess which is my local server :stuck_out_tongue:
@Andybee my guess is a local server will perform the same as it looks like a bad sketch and remember you are then responsible for maintaining the server.
I don’t like the look of your loop() , your terminal.flush() calls and syncing a pin within the pin read function.
Suggest you mod your sketch before considering a server change.
the latest version with all your help but the problem still exists. even the terminal widget only prints half of the text message now.
#include <Blynk.h>
#include <DHT.h>
   stepper1.runToNewPosition(param.asInt());  // Move stepper to new position
     focuserst1 = param.asInt() * (30 / 4150); // convert value to mm distance
//terminal.flush();
//Blynk.syncVirtual(V10);
BLYNK_WRITE(V30) {  //autoguider focuser slider value
    stepper2.runToNewPosition(param.asInt());  // Move stepper to new position
      focuserst2 = param.asInt() * (60 / 6150); // convert value to mm distance
//terminal.flush();
//Blynk.syncVirtual(V30);
 // terminal.flush();
    terminal.flush();
      dht.begin();
    timer.setInterval(3000, dewreading);
  stepperenables();
void dewreading() {
 if (h > 70){
 if (h < 65){
Are V0, V6 and V7 value display widgets or something else?
I am guessing you think you are sending temperature to V0 with 1 decimal place. That’s not the case, you are sending an array of values to V0 i.e. temperature to [0] and 1 to [1]. This can have some strange effects depending what the widget is.
The syntax should be something like:
Blynk.virtualWrite(V0, String(t, 1));
Other than Terminal commands in setup() I don’t see where you are sending anything to V1 so flush() serves no purpose. What do you think you are sending to Terminal and where is it in your sketch?
Again thanks for the support. the temperature, humidity and dew point at the moment are displayed gauge values but at some point they will be a temperature compensation for the focuser’s and the dew control to switch on heaters. The terminal widget has been removed along with the terminal flush. but still the sliders are an issue.
#include <Blynk.h>
#include <DHT.h>
char auth[] = "83a7ec4897b24c12ad99ec98e3dc0458";
//setup the Sliders to control the Stepper motor position
BLYNK_WRITE(V0) { //Main focuser slider value
     focuserst1 = (param.asInt() / 138.333); // convert value to mm distance
  Blynk.virtualWrite(V2, focuserst1);
BLYNK_WRITE(V10) {  //autoguider focuser slider value
      focuserst2 = (param.asInt() / 102.5); // convert value to mm distance
        Blynk.virtualWrite(V12, focuserst2);
//setup the PushButtons to control the Stepper motor position
BLYNK_WRITE(V1) // main focuser stepper enable on/off
BLYNK_WRITE(V11) //autoguider stepper enable on/off
//***********define inputs
    dht.begin();
//****** Stepper motor variables ************************
  stepperenables();
void dewreading() {
  Blynk.virtualWrite(V20, t);
  Blynk.virtualWrite(V21, h);
  Blynk.virtualWrite(V22, dewPoint(t, h));
 if (h > 70){
 if (h < 65){
@Andybee what range settings do you have for the sliders and is data mapping for the sliders disabled?
What is V2?
Originally I had a range of 0-1023 when I map the value. This was when I used a 10k pot for the distance. The 2 steppers are set for quarter stepping so now the range is 0 to 6150 and 0 to 4150. V2 and V12 convert the slider values into mm travel distance as the main focuses is 30mm travel and the autoguider is 60mm travel. It gives me a visual understanding of the position. The info forms part of my settings when I want to go back and view an object in the night sky.
So 44.46mm for main focus and 40.48mm for autoguider. Where do you get 30 and 60mm from?
How long does it take stepper1 to move to position 6150 (44.46 mm)?
Note runToNewPosition is a blocking command.
V2 is calculated from focuserst1 from the slider value divided by 138.333 and V12 focuserst2 slider value divided by 102.5. Full travel time is up to 5 seconds it could take a lot longer. Speed was not the Requirement very fine adjustment is the most important criteria.
any advise on alternative stepper control would be welcome.
I meant what widget is it, I know how the calcs work and that’s why I questioned your figures as mathematically they are wrong.
What does this mean, max 5 seconds, 5 days or something else?
Perhaps use a Step Widget instead of sliders… I don’t think sliders have a very fine range, or at least hard to move carefully, depending on screen size and device digitizer sensitivity, etc.
Also, the only thing you have on a timer is your temp/hum sensor (PS - the DHT11 is very low quality, ±2 deg, etc.) but your stepper routines are running full tilt, do they need hundredths/thousandths of a second response time? It looks like at a slight twitch of a slider and your code is running many fine stepper adjustments per second.
