rapgar
August 22, 2015, 5:21am
1
Does anyone have a bit of sample code working with multiple virtual pins in boolean logic arguments? I am trying to require two logical High’s in order to turn on a relay but can’t seem to get this right. All comments appreciated.
Thanks,
R
int enableState = LOW;
int timerState = LOW;
BLYNK_WRITE(1)
enableState = (param.asInt());
BLYNK_WRITE(2)
timerState = (param.asInt());
if (enableState && timerState == HIGH){
digitalWrite(2, LOW);
digitalWrite(2, HIGH);
Pavlo
August 22, 2015, 12:35pm
2
When using virtual pins, change HiGH and LOW to 1 and 0 respectively.
Also, too many parentheses here:
Change to:
enableState = param.asInt();
NickM
August 23, 2015, 9:38am
3
Also this line is a bit counter intuitive,
You might like to try
if( (enableState == HIGH) && (timerState == HIGH) ){
(yes it has to many parentheses, but they help show how things are grouped).
Also, you can get away with
if( enableState && timerState ){
rapgar
August 30, 2015, 8:27pm
4
Nick, Pavel,
Still wrestling with this,… I have followed your advice and the syntax is correct I believe. I have placed the IF statement in ‘void loop’ and get the following errors on the serial monitor;
[0] Blynk v0.3.0
[0] Getting IP...
[1870] My IP: 192.168.1.209
[5001] Connecting to cloud.blynk.cc:8442
[5233] Ready (ping: 60ms).
[5257] Trouble detected: http://tiny.cc/blynk-bug#flood
[10234] Connecting to cloud.blynk.cc:8442
[10472] Ready (ping: 64ms).
[10492] Trouble detected: http://tiny.cc/blynk-bug#flood
[15473] Connecting to cloud.blynk.cc:8442
[15710] Ready (ping: 63ms).
[15731] Trouble detected: http://tiny.cc/blynk-bug#flood
Where is the proper place for this code when using Blynk?
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h> // This part is for Ethernet stuff
char auth[] = "3fa959f4f931489ab215d889ea92e369"; // Put your Auth Token here. (see Step 3 above)
int enableZone1 = 0;
int timerZone1 = 0;
int manualZone1 = 0;
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
// Set all Arduino outputs to HIGH in respect to Relay Board
pinMode(2, OUTPUT); // Zone 1
pinMode(3, OUTPUT);
digitalWrite(3, HIGH);
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
pinMode(5, OUTPUT);
digitalWrite(5, HIGH);
pinMode(6, OUTPUT);
digitalWrite(6, HIGH);
pinMode(7, OUTPUT);
digitalWrite(7, HIGH);
pinMode(8, OUTPUT);
digitalWrite(8, HIGH);
pinMode(9, OUTPUT);
digitalWrite(9, HIGH);
BLYNK_WRITE(0)
enableZone1 = param.asInt();
BLYNK_WRITE(1)
timerZone1 = param.asInt();
BLYNK_WRITE(2)
manualZone1 = param.asInt();
BLYNK_WRITE(3)
if (param.asInt()) {
digitalWrite(3, LOW);
Blynk.virtualWrite(13, HIGH);
Blynk.virtualWrite(13, LOW);
BLYNK_WRITE(4)
digitalWrite(4, LOW);
Blynk.virtualWrite(14, HIGH);
Blynk.virtualWrite(14, LOW);
BLYNK_WRITE(5)
digitalWrite(5, LOW);
Blynk.virtualWrite(15, HIGH);
Blynk.virtualWrite(15, LOW);
if ((enableZone1 == HIGH) && (timerZone1 == HIGH)) {
Blynk.virtualWrite(23, HIGH); }
else {
Blynk.virtualWrite(23, LOW); }
Pavlo
August 31, 2015, 3:33am
5
there is a link for your error: http://tiny.cc/blynk-bug#flood
rapgar
August 31, 2015, 5:22am
6
Thanks Pavel,
I was finally able to get that working. I posted the complete code on our Missing Virtual Pins thread as I was able to duplicate the problem.
R
rapgar
July 26, 2016, 5:23pm
7
Hey Pavel,
I apologize for grabbing an old thread…
It has been a awhile since I checked in and I see many positive changes. Congratulations on all the progress! I can’t seem to get at any of my old projects. I previously logged in under "arduino@rapgar.com ". Have all these old projects been purged?
Thx,
rapgar
Dmytro
July 26, 2016, 6:42pm
8
@rapgar Hello. Look like yes. You need to create account again.
