hamza2
July 11, 2020, 11:10am
1
THIS IS MY CODE
HOW TO CONNECT IT WITH BLYNK USING USB
#include <DFRobot_BME280.h>
#define SEA_LEVEL_PRESSURE 1013.25f
#define BME_CS 10
DFRobot_BME280 bme; //I2C
float temp, pa, hum, alt;
// I2c default address is 0x76, if the need to change please modify bme.begin(Addr)
if (!bme.begin(0x77)) {
Serial.println("No sensor device found, check line or address!");
while (1);
Serial.println("-- BME280 DEMO --");
temp = bme.temperatureValue();
pa = bme.pressureValue();
hum = bme.humidityValue();
alt = bme.altitudeValue(SEA_LEVEL_PRESSURE);
Serial.print("Temp:");
Serial.print(temp);
Serial.println(" C");
Serial.print("Pa:");
Serial.print(pa);
Serial.println(" Pa");
Serial.print("Hum:");
Serial.print(hum);
Serial.println(" %");
Serial.print("Alt:");
Serial.print(alt);
Serial.println(" m");
Serial.println("------END------");
@hamza2 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
You should start by reading this:
and use these principals to move everything out of your void loop, and remove the delay from your code.
Then take a look at the Sketch Builder to see how to add-in the Blynk code for your device and connection type.
hamza2
July 17, 2020, 4:54pm
4
I tried this but I didn’t get any data
#define BME_CS 10
#include <ESP8266_Lib.h>
char auth[] = "#####";
char ssid[] = "#####";
char pass[] = "######";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
BlynkTimer timer; // Announcing the timer
bme.begin(0x77);
// Set ESP8266 baud rate
void sensorDataSend()
alt = bme.altitudeValue(SEA_LEVEL_PRESSURE); // reading sensor from analog pin
Blynk.virtualWrite(V1, temp); // sending sensor value to Blynk app
Blynk.virtualWrite(V2, pa);
Blynk.virtualWrite(V3, hum);
Blynk.virtualWrite(V4, alt);
Blynk.run(); // run Blynk magic
timer.run(); // run timer every second
That’s because you missed-out the bit where you add a timer in your void setup which calls your sensorDataSend on a regular basis.
In void setup() you need to declare that your function sensorDataSend() should run every 1000 milliseconds, (which is 1 second).
timer.setInterval(1000L, sensorDataSend); //timer will run every sec
hamza2
July 17, 2020, 5:20pm
6
Thank you,
but even after I add it to the code still the same problem
no data appears
after that disconnect
did it work before?
Honestly i do not use this sensor, or have one to test with, so take this as you will. Looking at the DFRobot_BME280.h github page, all of the examples use the wire.h library as well. I do not see it in your sketch. As mentioned I do not use this sensor, so it may not be needed, just an observation.
hamza2:
bme.begin(0x77);
Are you sure that your sensor is at address 0x77 ?
You should all some serial print statements to your code so that you can see what readings (if any) are coming from your sensor.
hamza2
July 17, 2020, 6:14pm
9
Yes , it worked well
I get results in the serial monitor
Do you want to share your latest code, and your serial monitor output showing the Blynk connection, readings and disconnection?
