Hello again all.
I have new problem about the project that I have posted before.
I have a linear actuator which I have instaled 2 reed magnetic sensor to determine direction and position. When I test it without blynk it runs very well, when the actuator extends it displays value from 0 to 400 and when the actuator retracts it displays value from 400 to 0.
But when I want to send the value to my phone use blynk, it sends the wrong value, when it extends only send data from 0 to 60, and when it retract it send 60 to 80 not decrease the value. I guess it because the blynktimer which delayed the reading of the sensor.
Plase help, how to send true value which represent the position if the actuator.
Mega+esp8266 as a shield, android pie.
This is the code.
#define A 22
#define B 23
int counter = 0;
int diam;
int akhir;
float volt;
#include <ESP8266_Lib.h>
char auth[] = "54737a98fcd843968facd53968b53691";
char ssid[] = "jonihermawanto";
char pass[] = "123456789";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
void sensor(){
diam=digitalRead(A);
if (diam!=akhir){
if(digitalRead(B)!=diam){
counter ++;
}else{
counter --;
Serial.print("Posisi : ");
Serial.println(counter);
Blynk.virtualWrite(V5, counter);
akhir=diam;
void setup (){
pinMode(A, INPUT);
pinMode(B, INPUT);
Serial.begin (9600);
akhir=digitalRead(A);
timer.setInterval(100 , sensor);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
void loop (){
