Holla, i need your guidance for my last project in university. BlynkTimer on my code doesn’t work when i put pinMode for ultrasonic sensor in void setup. But before that, BlynkTimer can work properly. It would be a happiness for me if you can guide me, thank you!
That’s my code :
#include <ESP8266_Lib.h>
char auth[] = "*******";
char ssid[] = "*******";
char pass[] = "*******";
SoftwareSerial EspSerial(2, 3); // TX, RX
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
const int WP_PIN = 6;
#include <Servo.h>
Servo servo;
#include <virtuabotixRTC.h>
//CLK, DAT, RST
virtuabotixRTC myRTC(8, 9, 10);
///Sensor Ultrasonic 1
#define echopin1 4
#define trigpin1 5
//Sensor Ultrasonic 2
#define echopin2 11
#define trigpin2 12
// Set ESP8266 baud rate
pinMode (trigpin1, OUTPUT);
pinMode (echopin1, INPUT);
Serial.println("Sensor Ultrasonic 1 Terpasang");
pinMode (trigpin2, OUTPUT);
pinMode (echopin2, INPUT);
Serial.println("Sensor Ultrasonic 2 Terpasang");
pinMode(WP_PIN, OUTPUT);
Serial.println("Pompa Air Terpasang");
servo.attach(7);
Serial.println("Motor Servo Terpasang");
// myRTC.setDS1302Time(00,27,16,1,26,7,2021);
timer.setInterval(10L, SensorUltrasonic);
timer.setInterval(10000L, JadwalMakanMinum);
BLYNK_CONNECTED(){
BLYNK_WRITE (V2) {
if (param.asInt() == 1) {
servo.write(180);
Serial.println("Motor Servo Bergerak ke 180°");
else if (param.asInt() == 0) {
servo.write(0);
Serial.println("Motor Servo Bergerak ke 0°");
BLYNK_WRITE (V3) {
digitalWrite(WP_PIN, HIGH);
Serial.println("Pompa Air ON");
digitalWrite(WP_PIN, LOW);
Serial.println("Pompa Air OFF");
void JadwalMakanMinum()
myRTC.updateTime();
Serial.println("Waktu RTC Telah Diupdate");
Serial.print("Waktu Sekarang :");
Serial.print(myRTC.hours);
Serial.print(":");
Serial.print(myRTC.minutes);
Serial.print(":");
Serial.println(myRTC.seconds);
if (myRTC.hours == 12 && myRTC.minutes >= 00) {
servo.write(180);
Serial.println("Motor Servo Aktif");
else if (myRTC.hours == 12 && myRTC.minutes <= 01) {
servo.write(0);
Serial.println("Pemberian Makanan & Minuman Berhasil");
else {
Serial.println("Belum Jadwalnya Makan & Minum");
void SensorUltrasonic() {
digitalWrite(trigpin1, LOW);
delayMicroseconds(4);
digitalWrite(trigpin1, HIGH);
delayMicroseconds(10);
long t1 = pulseIn(echopin1, HIGH);
long cm1 = t1 / 29 / 2;
Serial.print("Jarak Sensor 1 : ");
Serial.print(cm1);
Serial.println(" cm");
digitalWrite(trigpin2, LOW);
digitalWrite(trigpin2, HIGH);
long t2 = pulseIn(echopin2, HIGH);
long cm2 = t2 / 29 / 2;
Serial.print("Jarak Sensor 2 : ");
Serial.print(cm2);
