BlynkSimpleSIM800.h problem: No such file or directory
Hello I am using simcom sim900 with arduino uno
But there is an error in the library, I don’t know what it is
This code…
  WARNING: GSM modem support is for BETA testing.
  You’ll need:
   - Blynk IoT app (download from App Store or Google Play)
   - Arduino Uno board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
#define BLYNK_TEMPLATE_ID           "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME           "Device"
#define BLYNK_AUTH_TOKEN            "YourAuthToken"
#define TINY_GSM_MODEM_SIM900
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[]  = "YourAPN";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
  // Set GSM module baud rate
  SerialAT.begin(115200);
  delay(3000);
  modem.restart();
  // Unlock your SIM card with a PIN
  //modem.simUnlock("1234");
  // to avoid delay() function!
If you’re using an Uno, why doubt have the Uni section of code commented-out, and the Mega section of code enabled?
Don’t you think it would be a good idea to share some details of the error?
Thanks Pete
I modified it but there is a bug and I don’t know why
I’m not sure where you found this sketch, but it seems to use a very old method that isn’t supported anymore.
In the Arduino IDE go to Example > Blynk > Boards_GSM > TinyGSM_SIM800_SIM_900 and you’ll see the currently supported method.
Thank you Pete
The problem has been resolved
The solution is in the following link
