I’m using an ESP32 wrover module and a sim800 GSM module to connect to the cloud. i downloaded the libraries and added on Arduino IDE. I finished my codes but it won’t verify sending me an error message thus: " BlynkSimpleSIM800.h : no such file or directory". i don’t know how to fix it.
@Flashyslash Please don’t post your unconnected issues in an existing topic.
I’ve moved your post to a new topic of its own.
A quick search by you would have revealed this topic, which has the answer you require…
Please use the search function in future before posting a question.
Ok Sir. Thanks
sir same problem , i have tried your solution but it didn’t work. Please help me sir
I’d suggest that you start a new “need help…” topic and provide all of the necessary information about your board, your software, the library versions you have installed, the exact error(s) you are getting etc etc etc.
That way we may be able to help.
