I use the SHT30 sensor to measure the temperature and humidity but having trouble connecting to the GPRS, the ESP does not send value to Blynk. Wifi is stable.
TTGO-TCALL.ino
For ESP32 TTGO-TCALL boards to run GSM/GPRS and WiFi simultaneously, using config portal feature
Library to enable GSM/GPRS and WiFi running simultaneously , with WiFi config portal.
Forked from Blynk library v0.6.1 https://github.com/blynkkk/blynk-library/releases
Built by Khoi Hoang https://github.com/khoih-prog/BlynkGSM_ESPManager
Licensed under MIT license
Version: 1.0.9
Version Modified By Date Comments
1.0.0 K Hoang 17/01/2020 Initial coding. Add config portal similar to Blynk_WM library.
1.0.1 K Hoang 27/01/2020 Change Synch XMLHttpRequest to Async (https://xhr.spec.whatwg.org/). Reduce code size
1.0.2 K Hoang 08/02/2020 Enable GSM/GPRS and WiFi running simultaneously
1.0.3 K Hoang 18/02/2020 Add checksum. Add clearConfigData()
1.0.4 K Hoang 14/03/2020 Enhance Config Portal GUI. Reduce code size.
1.0.5 K Hoang 20/03/2020 Add more modem supports. See the list in README.md
1.0.6 K Hoang 07/04/2020 Enable adding dynamic custom parameters from sketch
1.0.7 K Hoang 09/04/2020 SSID password maxlen is 63 now. Permit special chars # and % in input data.
1.0.8 K Hoang 14/04/2020 Fix bug.
1.0.9 K Hoang 31/05/2020 Update to use LittleFS for ESP8266 core 2.7.1+. Add Configurable Config Portal Title,
Default Config Data and DRD. Add MultiWiFi/Blynk features for WiFi and GPRS/GSM
#include "defines.h"
#include "Credentials.h"
#include "dynamicParams.h"
#include <SHT3x.h>
SHT3x Sensor;
void heartBeatPrint(void)
static int num = 1;
if (Blynk_WF.connected())
Serial.print(F("B"));
Serial.print(F("F"));
if (Blynk_GSM.connected())
Serial.print(F("G"));
if (num == 40)
Serial.println();
num = 1;
else if (num++ % 10 == 0)
Serial.print(F(" "));
void check_status()
static unsigned long checkstatus_timeout = 0;
#define STATUS_CHECK_INTERVAL 60000L
// Send status report every STATUS_REPORT_INTERVAL (60) seconds: we don't need to send updates frequently if there is no status change.
if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
// report status to Blynk
heartBeatPrint();
checkstatus_timeout = millis() + STATUS_CHECK_INTERVAL;
bool valid_apn = false;
bool GSM_CONNECT_OK = false;
// Set console baud rate
SerialMon.begin(115200);
Sensor.Begin();
while (!SerialMon);
SerialMon.print(F("\nStart TTGO-TCALL-GSM using "));
SerialMon.println(CurrentFileFS);
// Set-up modem reset, enable, power pins
pinMode(MODEM_PWKEY, OUTPUT);
pinMode(MODEM_RST, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_PWKEY, LOW);
digitalWrite(MODEM_RST, HIGH);
digitalWrite(MODEM_POWER_ON, HIGH);
SerialMon.println(F("Set GSM module baud rate"));
// Set GSM module baud rate
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(3000);
Serial.println(F("Use WiFi to connect Blynk"));
#if USE_BLYNK_WM
// Use configurable AP IP, instead of default IP 192.168.4.1
Blynk_WF.setConfigPortalIP(IPAddress(192, 168, 100, 1));
// Use channel = 0 => random Config Portal WiFi channel to avoid conflict
Blynk_WF.setConfigPortalChannel(0);
// Set personalized Hostname
Blynk_WF.begin("TTGO-TCALL-GSM");
#else
Blynk_WF.begin(wifi_blynk_tok, ssid, pass, blynk_server, BLYNK_HARDWARE_PORT);
Blynk_GSM.config(modem, gsm_blynk_tok, blynk_server, BLYNK_HARDWARE_PORT);
GSM_CONNECT_OK = Blynk_GSM.connectNetwork(apn, gprsUser, gprsPass);
if (GSM_CONNECT_OK)
Blynk_GSM.connect();
#endif
#if USE_BLYNK_WM
Blynk_WF_Configuration localBlynkGSM_ESP32_config;
Blynk_WF.getFullConfigData(&localBlynkGSM_ESP32_config);
Serial.print(F("gprs apn = "));
Serial.println(localBlynkGSM_ESP32_config.apn);
if (String(localBlynkGSM_ESP32_config.apn) == NO_CONFIG)
Serial.println(F("No valid stored apn. Must run WiFi to Open config portal"));
valid_apn = false;
valid_apn = true;
for (int index = 0; index < NUM_BLYNK_CREDENTIALS; index++)
Blynk_GSM.config(modem, localBlynkGSM_ESP32_config.Blynk_Creds[index].gsm_blynk_token,
localBlynkGSM_ESP32_config.Blynk_Creds[index].blynk_server, localBlynkGSM_ESP32_config.blynk_port);
GSM_CONNECT_OK = Blynk_GSM.connectNetwork(localBlynkGSM_ESP32_config.apn, localBlynkGSM_ESP32_config.gprsUser,
localBlynkGSM_ESP32_config.gprsPass);
if (GSM_CONNECT_OK)
if ( Blynk_GSM.connect() == true )
break;
#endif
#if (USE_BLYNK_WM && USE_DYNAMIC_PARAMETERS)
void displayCredentials(void)
Serial.println("\nYour stored Credentials :");
for (int i = 0; i < NUM_MENU_ITEMS; i++)
Serial.println(String(myMenuItems[i].displayName) + " = " + myMenuItems[i].pdata);
#endif
void cambien()
Sensor.UpdateData();
Blynk.virtualWrite(V1, Sensor.GetTemperature());
Blynk.virtualWrite(V2, Sensor.GetRelHumidity());
Blynk.syncVirtual(V1, V2);
delay(333);
cambien();
Blynk_WF.run();
#if USE_BLYNK_WM
if (valid_apn)
Blynk_GSM.run();
#else
Blynk_GSM.run();
#endif
check_status();
static bool displayedCredentials = false;
if (!displayedCredentials)
if (!strlen(myMenuItems[i].pdata))
break;
if ( i == (NUM_MENU_ITEMS - 1) )
displayedCredentials = true;
displayCredentials();
#endif
