I had working BlynkEdgenet code developed in PIO but then had compile errors . Having tried everything and failed I just tried compiling the example code for ESP32 in the Arduino IDE 2.3.2 and the only change I made was valid credentials but the code fails with
Compilation error: ‘WiFi’ was not declared in this scope
Code is below, Ive removed credentials
ESP32, Arduino, Raspberry Pi and the likes over the Internet.
You can easily build mobile and web interfaces for any
Downloads, docs, tutorials: https://www.blynk.io
Sketch generator: https://examples.blynk.cc
Blynk community: https://community.blynk.cc
Follow us: https://www.fb.com/blynkapp
https://twitter.com/blynk_app
Blynk.Edgent implements:
- Blynk.Inject - Dynamic WiFi credentials provisioning
- Blynk.Air - Over The Air firmware updates
- Device state indication using a physical LED
- Credentials reset using a physical Button
/* Fill in information from your Blynk Template here */
/* Read more: https://bit.ly/BlynkInject */
#define BLYNK_TEMPLATE_ID "XXXXXXXXXX"
#define BLYNK_TEMPLATE_NAME "LED ESP32"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_ESP32_DEV_MODULE
//#define USE_ESP32C3_DEV_MODULE
//#define USE_ESP32S2_DEV_KIT
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
//#define USE_TTGO_T_OI
#include "BlynkEdgent.h"
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
