Hi, I use the gauge widget a lot to display temperature on a lot of projects. In Blynk legacy you could select a gradiated colour scale, eg green at the cooler end, red at the hotter end, a good visual effect.
In Blynk 2.0 this option has disappeared from the gauge widget.
It appears that now we can only select a single colour.
Is it possible to restore previous functionality? Workaround?
thnx
billd
) Haven’t delved into the details for a lot of the newer widgets.
